[Nek5000-users] compilation error
Fri May 18 01:37:04 CDT 2012
Warnings are fairly standard.
Is it able to run?
Paul
On Fri, 18 May 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Sir,
> Thank you for your kind response.
> I was not using using gfortran but using gcc( 3.4.6 version ) and g77.
> After using gfortran(GNU Fortran 95 (GCC) 4.1.0 and gcc( 3.4.6 version ). I
> could compile makenek  but with warnings.Below are the warnings which I get
> while compiling.
> */home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/errmem.c: In function
> `fail':
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/errmem.c:15: warning:
> `noreturn' function does return
> gcc -c  -O2 -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/crystal.c -o
> obj/jl_crystal.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/findpts.c -o
> obj/jl2_findpts.o
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9584*
> *               IF(DFLAG) 50,10,30
>        1
> Warning: Obsolete: arithmetic IF statement at (1)
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9623*
> *          IF(DFLAG)120,80,100
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9764*
> *      GO TO IGO,(120,150,180,210)
>              1
> Warning: Obsolete: Assigned GOTO statement at (1)
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9770*
> *               ASSIGN 120 TO IGO
>        1
> Warning: Obsolete: ASSIGN statement at (1)
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9782*
> *               ASSIGN 150 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9795*
> *               ASSIGN 180 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9806*
> *               ASSIGN 210 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:9815*
> *          IF(DFLAG)250,230,240
>        1
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/findpts_local.c
> -o obj/jl2_findpts_local.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/obbox.c -o
> obj/jl2_obbox.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/poly.c -o
> obj/jl2_poly.o
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17100*
> *               IF(SFLAG) 50,10,30
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17139*
> *          IF(SFLAG)120,80,100
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17277*
>              1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17283*
> *               ASSIGN 120 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17295*
> *               ASSIGN 150 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17308*
> *               ASSIGN 180 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17319*
> *               ASSIGN 210 TO IGO
>        1
> In file
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/3rd_party/blas.f:17328*
> *          IF(SFLAG)250,230,240
>        1
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/lob_bnd.c -o
> obj/jl2_lob_bnd.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/findpts_el_3.c
> -o obj/jl2_findpts_el_3.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/findpts_el_2.c
> -o obj/jl2_findpts_el_2.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/sparse_cholesky.c
> -o obj/jl2_sparse_cholesky.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/xxt.c -o
> obj/jl2_xxt.o
> -DPREFIX=jl_
> /home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek/jl/../jl2/fcrs.c -o
> obj/jl2_fcrs.o
> gfortran -c  -O2 -fcray-pointer -fdefault-real-8 -x f77-cpp-input
> -I/home/secg/cfd/vinayas/nek5000/testnek/rayleigh1
> -I/home/secg/cfd/vinayas/nek5000/nek5_svn/trunk/nek -I./
> /home/secg/cfd/vinayas/nek5000/testnek/rayleigh1/rayleigh.f -o
> obj/rayleigh.o
> gfortran -o nek5000  obj/rayleigh.o obj/drive.o obj/drive1.o obj/drive2.o
> obj/plan4.o obj/bdry.o obj/coef.o obj/conduct.o obj/connect1.o
> obj/connect2.o obj/dssum.o obj/edgec.o obj/eigsolv.o obj/gauss.o
> obj/genxyz.o obj/navier1.o obj/makeq.o obj/navier0.o obj/navier2.o
> obj/navier3.o obj/navier4.o obj/prepost.o obj/speclib.o obj/map2.o
> obj/turb.o obj/mvmesh.o obj/ic.o obj/ssolv.o obj/planx.o obj/math.o
> obj/mxm_wrapper.o obj/hmholtz.o obj/gfdm_par.o obj/gfdm_op.o
> obj/gfdm_solve.o obj/subs1.o obj/subs2.o obj/genbox.o obj/gmres.o
> obj/hsmg.o obj/convect.o obj/induct.o obj/perturb.o obj/navier5.o
> obj/navier6.o obj/navier7.o obj/navier8.o obj/fast3d.o obj/fasts.o
> obj/calcz.o obj/byte.o obj/chelpers.o obj/byte_mpi.o obj/postpro.o
> obj/cvode_driver.o obj/nek_comm.o obj/init_plugin.o obj/setprop.o
> obj/qthermal.o obj/cvode_aux.o obj/makeq_aux.o obj/papi.o obj/ssygv.o
> obj/dsygv.o obj/mxm_std.o obj/blas.o obj/comm_mpi.o obj/mpi_dummy.o
> obj/jl2_gs.o obj/jl2_sort.o obj/jl2_sarray_transfer.o obj/jl2_sarray_sort.o
> obj/jl2_gs_local.o obj/jl2_crystal.o obj/jl2_comm.o obj/jl2_tensor.o
> obj/jl2_fail.o obj/jl2_fcrystal.o obj/jl_tuple_list.o obj/jl_transfer.o
> obj/jl_sort.o obj/jl_fcrystal.o obj/jl_errmem.o obj/jl_crystal.o
> obj/jl2_findpts.o obj/jl2_findpts_local.o obj/jl2_obbox.o obj/jl2_poly.o
> obj/jl2_lob_bnd.o obj/jl2_findpts_el_3.o obj/jl2_findpts_el_2.o
> obj/jl2_sparse_cholesky.o obj/jl2_xxt.o obj/jl2_fcrs.o
> #                  Compilation successful!                  #
>   text    data     bss     dec     hex filename
> 2073815    2992 24176824        26253631        190993f nek5000*
> Thanks and regards
> Vinaya
> On Thu, May 17, 2012 at 5:51 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Are you using gfortran and gcc?
>> I would suggest setting these as your compiler in makenek
>> and also settig IFMPI to false in the makenek script.
>> Then,
>> makenek clean
>> before resuming your attempt to compile.
>> Best regards,
>> Paul
>> On Thu, 17 May 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>  Dear Sir,
>>> Iam trying to compile makenek in (x86_64 x86_64 x86_64 GNU/Linux)
>>> environment
>>> the error is:
>>> *Unable to detect compiler!
>>>       - don't know how to promote datatype REAL to 8 bytes
>>>       - don't know how to invoke the C pre-processor (CPP) before
>>> compilation
>>>      Please edit the makefile and specify the requested compiler flags
>>> using the P variable.*
>>> *generating makefile ...*
>>> Plz help me in this regard
>>> *Vinaya Sivanandan*
>>> *Pune*
>>> ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> *Vinaya Sivanandan*
> *Pune*
