[Nek5000-users] How to use an external lib with nek5000
Wed Mar 28 08:28:32 CDT 2012
nek5000-users at lists.mcs.anl.gov a écrit :
> Hi Can,
> Another way to link Nek5000 with other libraries, is through makenek directly by specifying appropriate USR_LFLAGS
> Best.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Wednesday, March 28, 2012 7:54:17 AM
> Subject: Re: [Nek5000-users] How to use an external lib with nek5000
> Can,
> If I need to modify the makefile, I usually run makenek once
> to have it generate the appropriate makefile, then edit it
> (say, to add the library links).
> Make certain you make a copy of your edited makefile or it
> will be overwritten by a future "makenek" execution.
> This is one way... but there are probably some better ones.
> If you just want to add routines from the library you can
> include them directly into your .usr file and call them from
> there.
> Hope this helps.
> Paul
> On Wed, 28 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi neks !
>> I would like to use the subroutines in the JMFFT lib (Fast Fourrier Transform
>> library)
>> http://www.idris.fr/data/publications/JMFFT/
>> How can i do this with nek5000??
>> B.regards
>> Can
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Hi again
i could resovle the problem thx to you
thank you
Can
