[Nek5000-users] The first time step in a Nek file must contain a mesh
Fri Mar 2 07:39:27 CST 2012
nek5000-users at lists.mcs.anl.gov a écrit :
> These parameters should definitely have yielded as street. Typically
> the street forms after t=100-200 convective time units.
> What is your lx1 value in SIZE ?
> What are p101 and p103 in the .rea file ?
> Paul
>> Thank you very much to both of you, these are really useful infos :)
>> But i got another question, i can visualize now the vorticity field,
>> but i don't see any v.karman vortexes, i just see some vortexes
>> around my circle (diameter 1) obstacle.
>> My bc are as follow : unit-diameter cylinder is centered at (0,0) in
>> a box on [-15,35] x [-15,15]. (picked up the .rea on the ext_cyl
>> example)
>> left : velocity inlet with 1m/s
>> right : pressure output
>> top and bottom , periodic
>> Re= 160 (>50 for the instability)
>> dt=0.01
>> End of simulation Time = 550
>> can this be because of the meshe not being tight enough ??
>> B.regards
>> Can
> Nek5000-users mailing list
lx1=10
0.00000     p101 Number of additional modes to filter
1.00000     p102 Dump out divergence at each time step
