[Nek5000-users] middle plane flux
Thu Mar 1 15:09:57 CST 2012
Dear NEKs
I am using NEK5000 to simulate turbulent flow in duct (channel with
side walls). I would like to calculate flux at the middle slab of the
domain (a zy plane) in each time step in order to compare it with my
bulk (Z is my streamwise direction). Attached file is the .usr file
containing the routine I wrote to compute the mid-flux. Seems works
fine for the primitive tests; however, when I increase number of
processors to 256 or upper it gives me NaNs. I was wondering if you
could help me with that.
With many thanks in advance.
Azad
This message was sent using IMP, the Internet Messaging Program.
c-----------------------------------------------------------------------
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
C
      udiff =0.
      utrans=0.
      return
      end
      subroutine userf  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
c      include 'TRIPF'
      ffx = 0.0
      ffy = 0.0
      ffz = 0.0
      return
      end
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
C
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userchk    ! called once per step
      include 'SIZE'
      include 'TOTAL'
       if (istep.gt.10) call flux_2d(vz)
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=0.0
      uy=0.0
      uz=0.0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      real pi,zs
      real a,s
      ux = 0.
      uy = 0.
      uz = 3.0*(2.0-x**2-y**2)/4.0
      s = 1.0
      call random_number(a)
      a=a-0.5
      ux=ux+s*a
      a=a-0.5
      uy=uy+s*a
      a=a-0.5
      uz=uz+s*a
      return
      end
C=======================================================================
      SUBROUTINE usrdat
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER'    ! For nelx,nely,nelz - needed for z_average
      nelx = 22
      nely = 22
      nelz = 95
      RETURN
      END
      subroutine usrdat2
      return
      end
      subroutine usrdat3
      return
      end
      subroutine flux_2d(uz)
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER'
      real uz(1)
      common /scravg/ w(1),w1(1),w2(1)
      real Re_bulk, Re_mid
      Re_bulk = 1.0 / param(2)
      call zy_plane_average(w,uz,w1,w2)
      Re_mid = Re_bulk * w(1)
      if (nid.eq.0) then
         open(unit=37,access='append',file='history')
c	 write(37,'(A)') '  Time   <flux>   '
	 write(37,3) time,Re_mid
         if (nid.eq.0.and.istep.eq.NTSTEPS) then
            close(37)
         endif
 3       format(1p15e17.9)
      endif
c      write(*,*) 'mid flux:::::::::', w
      return
      end
      subroutine zy_plane_average(ua,u,w1,w2)
c
c     Compute the zy average of quantity u() in the mid plane of the domain in the x direction.
c
      include 'SIZE'
      include 'GEOM'
      include 'PARALLEL'
      include 'WZ'
      include 'ZPER'
      real ua(1),u (nx1,ny1,nz1,nelv)
     $    ,w1(1),w2(1)
      integer e,eg,ex,ey,ez
      real dy2,dz2
      integer frame, plane
C     Find the mid-plane element-number for even/odd number of elements in the x direction
      if (mod(nelx,2).eq.0) then
         frame = (real(nelx) / 2.0) + 1
         plane = 1
      else if (mod(nelx,2).eq.1) then
         frame = floor(real(nelx) / 2.0)
         plane = floor(real(nx1) / 2.0) + 1
      end if
      nelxy = nelx*nely
      if (nelxy.gt.lelx*lely) call exitti
     $ ('ABORT IN yz_plane_average.Increase lelx*lely in SIZE:$',nelxy)
      call rzero(ua,1)
      call rzero(w1,1)
      do e=1,nelt
         eg = lglel(e)
         call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
         i = plane
         if (ex.eq.frame) then
         do j=1,ny1
         do i=plane,plane
            dy2 = 1.0*( ym1(i,ny1,k,e) - ym1(i,1,k,e) ) ! Computing the length of the elements in the y direction
            dz2 = 1.0                                   ! Assuming uniform in "z" direction
            do k=1,nz1
               ua(i)=ua(i)+dy2*wym1(j)*dz2*wzm1(k)*u(i,j,k,e)
               w1(i)=w1(i)+dy2*wym1(j)*dz2*wzm1(k) ! the weigths which must be equal to the yz area
            enddo
         enddo
         enddo
         endif
      enddo
      call gop(ua,w2,'+  ',mxy)
      call gop(w1,w2,'+  ',mxy)
         ua(:) = ua(:) / w1(:)   ! Normalize
      return
      end
c automatically added by makenek
      subroutine usrsetvert(glo_num,nel,nx,ny,nz) ! to modify glo_num
      integer*8 glo_num(1)
      return
      end
