[Nek5000-users] Add a forcing term on scalar equation
Fri Jan 20 07:25:48 CST 2012
Iman,
These can be coupled explicitly, but not implicitly.   Usually, however,
this is sufficent.  Equation are of the form:
    u_t = NS +  f(u,T)
    T_t = energy eq. + q(u,T)
f & q explicit.   The code will take care of the bookkeeping.
Paul
On Fri, 20 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks.
> So I just used the "USERQ" to implement the forcing term to scalar filed explicitly.
> In the next step, I want to coupled the scalar field to Navier-Stokes equation using a forcing term.
> In this case, the forcing term is a function of scalar field and I would like to implement it implicitly.
> As far as I know, if I used USERF, the scheme is explicit. So how can I add a forcing term to N-S equation implicitly!?
> Iman
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Thursday, January 19, 2012 4:20 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Add a forcing term on scalar equation
> It's actually evaluated explicitly, so you shold be ok.
> Paul
> On Thu, 19 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi
>> I would like to add a forcing term to the scalar equation.
>> According to the Nekton manual, Chapter 5, the forcing term is treated implicitly and the convective term is integrated using the third order Adam_Bashforth scheme (AB3).
>> For my case, the forcing term is a nonlinear function of the scalar field, so I cannot use the implicit scheme and I should lump it with the AB3.
>> Therefore, could you please guide me and indicate where in the code I can find the implementation of AB3 for the convective term of passive scalar?
>> Cheers
>> Iman
> Nek5000-users mailing list
