[Nek5000-users] Nek5000-users Digest, Vol 35, Issue 10
Thu Jan 12 15:40:57 CST 2012
Hi Katie;
The AMG scheme is working properly now. Thanks very much for your help.
Best regards
Azad
Quoting nek5000-users-request at lists.mcs.anl.gov:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Nek5000-users Digest, Vol 35, Issue 9
>       (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Nek5000-users Digest, Vol 35, Issue 9
> Message: 1
> Date: Thu, 12 Jan 2012 21:34:35 +0100
> From: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 35, Issue 9
> To: nek5000-users at lists.mcs.anl.gov
> Message-ID: <20120112213435.25972q7ffsnuvb2z at www.mech.kth.se>
> Content-Type: text/plain;	charset=ISO-8859-1;	DelSp="Yes";
> 	format="flowed"
> Hi Katie;
> Thanks for updating the page. I did exactly the same as it's suggested
> in the updated page. After ./run of the script in amg_matlab I got
> this error:
> Computing Lagrange multiplier governing matrix skeleton ... nnz = 25.
> Computing Lagrange multiplier governing matrix (C code) ... done.
> CG to obtain Lagrange multipliers ... 1 iterations.
> Computing interpolation weights (C code) ... done.
> Sparsifying R_f A P: compression = 0
> simple_sparsify: nnzs 4/4 (1)
> Level 6, dim(A) = 2
> Computing S = I - D^{-1/2} A D^{-1/2} ... done, nnz(S) = 2.
> Running coarsening heuristic ...
>    ratio = 0, n = 0, max Gershgorin radius = 1
>    ratio = 0.5, n = 1, max Gershgorin radius = 0
> connectivity = ??? Error using ==> fprintf
> Function is not defined for sparse inputs.
> Error in ==> coarse_par at 37
>          fprintf(1,'%g\n',max(lanczos(sparse(D*S*D))));
> Error in ==> amg_setup at 30
>                  [C F] = coarse_par(A,tolc);
> Error in ==> go at 20
> data = amg_setup(A, full(0*A(:,1)+1),ctol, tol, stol, wtol);
> I tried it for turbChannel test case as well as some other simplified
> test cases. I have got the same errors.
> Regards
> Azad
>> Today's Topics:
>>    1. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.gov)
>> Message: 1
>> Date: Thu, 12 Jan 2012 14:09:12 -0600
>> Subject: Re: [Nek5000-users] run-time hang up in gs_setup
>> Message-ID:
>> 	<CAFTrYW+ctDhLYVdJCh8mOpA6bB7j361o=vn7WaATYkEDCifYsw at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Hi Azad,
>> Earlier you had asked if a step was missing in the wiki with regards to the
>> amg files/scripts.  The has just been updated.
>> Can you tell me exactly what you did to run the turbChannel test?  And what
>> output you had from the amg_matlab/run step?
>> thanks,
>> Katie
>> On Thu, Jan 12, 2012 at 1:38 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Stefan;
>>> Unfortunately it does not work. first of all, ./run in amg_matlab does not
>>> produce anything (latest version). Using my version of the files (running
>>> turbChannel), the simulation crashed giving me this error:
>>> AMG  level 8: 3 iterations with rho = 0.680429
>>> AMG  level 9: 2 iterations with rho = 0.560188
>>> AMG: 144540 rows
>>> AMG: reading through row 1200, pass 1/121
>>> ERROR (proc 0000,
>>> /scratch/azad/codes/late/nek5_**svn/trunk/nek/jl/amg.c:875):
>>> AMG: data
>>> has more rows than given problem
>>> call exitt: dying ...
>>> Regards
>>> Azad
>>> Quoting
>>> nek5000-users-request at lists.**mcs.anl.gov<nek5000-users-request at lists.mcs.anl.gov>
>>>>        nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>> nek5000-users-owner at lists.mcs.**anl.gov<nek5000-users-owner at lists.mcs.anl.gov>
>>>> Today's Topics:
>>>> (nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>>> Message: 1
>>>> Date: Thu, 12 Jan 2012 18:09:48 +0100
>>>> From: nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>
>>>> To: nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>
>>>> Message-ID:
>>>>        <CAGTrLsaGQkuowxvfpK3AxvCtgCEk**as9YBJkX024qF2Sh7RcmdA at mail.**
>>>> gmail.com<CAGTrLsaGQkuowxvfpK3AxvCtgCEkas9YBJkX024qF2Sh7RcmdA at mail.gmail.com>
>>>> Hi Azad,
>>>> can you try to run the turbChannel example using AMG and the latest
>>>> version of the repo. Let me know if this works for you.
>>>> Stefan
>>>> On 1/11/12,
>>>> <nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>>
>>>> wrote:
>>>>> Dear Stefan and Aleks;
>>>>> Thanks for updating the wiki webpage regarding the AMG, although, I
>>>>> persume there must be another step also there exist, namely: copy the
>>>>> generated files from the amg_matlb to the running directory? (Or they
>>>>> should be remained there and one puts the generated .dat files after
>>>>> running the 3rd step?). By the way non of the versions I tried working
>>>>> (even 707!) despite the fact that I had a range of matlab versions
>>>>> tried. Hanging with the old version I had I compiled again and have
>>>>> got the four files which was rather fast (with the message at the end:
>>>>> Error contraction factor: 0.47...) I used them and every time during
>>>>> the run-time it crashed simply:
>>>>> AMG: reading through row 144540, pass 121/121
>>>>> AMG:   reading 0.071106 MB of W
>>>>> AMG:   reading 0.115601 MB of AfP
>>>>> AMG:   reading 0.132477 MB of Aff
>>>>> AMG level 1 F-vars: 440159
>>>>> AMG level 2 F-vars: 55146
>>>>> AMG level 3 F-vars: 28480
>>>>> AMG level 4 F-vars: 17051
>>>>> AMG level 5 F-vars: 7524
>>>>> AMG level 6 F-vars: 5711
>>>>> AMG level 7 F-vars: 5763
>>>>> AMG level 8 F-vars: 28583
>>>>> AMG level 9 F-vars: 5380
>>>>> AMG level 10 F-vars: 5737
>>>>> Application 731033 exit codes: 139
>>>>> Application 731033 exit signals: Killed
>>>>> Application 731033 resources: utime ~417s, stime ~3s
>>>>> Can you help me with that cause I believe this case still doable with
>>>>> correct AMG scheme.
>>>>> Many thanks
>>>>> Azad
>>>>>> Hi Azad,
>>>>>> I believe old AMG files should work up to and including revision 707
>>>>>> in case >you want to check AMG quickly.
>>>>>> Best.
>>>>>> Aleks
>>>>>> ----- Original Message -----
>>>>>> Sent: Tuesday, January 10, 2012 10:58:47 AM
>>>>>> Hi Azad,
>>>>>> your choice of lx1=8 is fine (it's our preferred sweet spot). If you
>>>>>> have a large element count (say > 300'000) the factorization in the
>>>>>> XXt setup phase may take hours. I guess that's why it looks like it's
>>>>>> hanging. Again, there is a known bug which looks the same. So can't
>>>>>> tell exactly what's causing your problem.
>>>>>> I just updated the Wiki: https://nek5000.mcs.anl.gov/**
>>>>>> index.php/Amg_matlab <https://nek5000.mcs.anl.gov/index.php/Amg_matlab>
>>>>>> Can you verify that it still fails.
>>>>>> -Stefan
>>>>>> Quoting
>>>>>> Today's Topics:
>>>>>>   1. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.**
>>>>>> gov <nek5000-users at lists.mcs.anl.gov>)
>>>>>>   2. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.**
>>>>>>   3. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.**
>>>>>> Message: 1
>>>>>> Date: Tue, 10 Jan 2012 06:01:29 -0600 (CST)
>>>>>> From: nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>>>>> Message-ID:
>>>>>> <Pine.LNX.4.64.1201100557250.**6026 at v8.mcs.anl.gov<Pine.LNX.4.64.1201100557250.6026 at v8.mcs.anl.gov>
>>>>>> Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
>>>>>> Hi Azad,
>>>>>> You are in record-setting territory for element counts! :)
>>>>>> Are you using the amg-based coarse-grid solver?
>>>>>> It is certain that you will need to do this (and,
>>>>>> therefore, you will need matlab to process the AMG
>>>>>> operators).   There is some discussion of the steps
>>>>>> on the wiki page.  We can walk you through this process
>>>>>> if you have any questions.
>>>>>> What value of lx1 are you using?
>>>>>> I would recommend fewer elements and a higher value of lx1.
>>>>>> I think it will be easier to manage the data, etc.
>>>>>> Paul
>>>>>> On Tue, 10 Jan 2012,
>>>>>> nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>>>>>  Dear NEKs;
>>>>>>> I am trying to run a simulation of a turbulent flow in a straight pipe
>>>>>>> in high Reynolds number (Re_tau = 1000). After generating the grid with
>>>>>>> PRENEK and extrude it using n2to3, the mesh ended up with 4,495,920
>>>>>>> elements. It compiled properly; however, trying to run it, hanged up in
>>>>>>> the last stage:
>>>>>>> verify mesh topology
>>>>>>>  -1.000000000000000         1.000000000000000       Xrange
>>>>>>>  -1.000000000000000         1.000000000000000       Yrange
>>>>>>>   0.000000000000000         25.00000000000000       Zrange
>>>>>>> done :: verify mesh topology
>>>>>>>  E-solver strategy:  1 itr
>>>>>>> mg_nx:            1            3
>>>>>>> mg_ny:            1            3
>>>>>>> mg_nz:            1            3
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>> gs_setup: 866937 unique labels shared
>>>>>>>  pairwise times (avg, min, max): 0.000241442 0.00019722 0.000265908
>>>>>>>  crystal router                : 0.000458177 0.000445795 0.000471807
>>>>>>>  used all_to_all method: pairwise
>>>>>>>  setupds time 5.6048E-02 seconds   1  2     4565612     4495920
>>>>>>>  setvert3d:   4    86046564   122013924    86046564    86046564
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>> gs_setup: 8041169 unique labels shared
>>>>>>>  pairwise times (avg, min, max): 0.00050716 0.000427103 0.00056479
>>>>>>>  crystal router                : 0.0040165 0.00392921 0.00411811
>>>>>>>  setupds time 1.0465E+00 seconds   2 4 86046564     4495920
>>>>>>> setup h1 coarse grid, nx_crs=            2
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>>  pairwise times (avg, min, max): 0.000233683 0.000197816 0.00024941
>>>>>>>  crystal router                : 0.000466869 0.00045588 0.000478101
>>>>>>> I was wondering if you could help me with that. I attached the run
>>>>>>> logfile and also genmap.out.
>>>>>>> Many thanks
>>>>>>> Azad
>>>>>> Message: 2
>>>>>> Date: Tue, 10 Jan 2012 13:35:22 +0100
>>>>>> Message-ID:
>>>>>>        <CAGTrLsaexkteQN1Y1NQ3FYz7Q2ab**b5YSLzOv+zeTwdvYXpD3Fw at mail.**
>>>>>> gmail.com<CAGTrLsaexkteQN1Y1NQ3FYz7Q2abb5YSLzOv%2BzeTwdvYXpD3Fw at mail.gmail.com>
>>>>>> Hi Azad,
>>>>>> We have seen similar situations. I think this has to do with a known
>>>>>> bug. Unfortunately this bug is hard to reproduce and we haven't
>>>>>> managed to fix it yet.
>>>>>> -Stefan
>>>>>> On 1/10/12,
>>>>>> wrote:
>>>>>>> Hi Azad,
>>>>>>> Paul
>>>>>>>  Dear NEKs;
>>>>>>>> with
>>>>>>>> in
>>>>>>>> the last stage:
>>>>>>>> mg_nx:            1            3
>>>>>>>> mg_ny:            1            3
>>>>>>>> mg_nz:            1            3
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> Many thanks
>>>>>>>> Azad
>>>>>>>>  ______________________________**_________________
>>>>>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>>>>> Message: 3
>>>>>> Date: Tue, 10 Jan 2012 17:58:47 +0100
>>>>>> Message-ID:
>>>>>> <1326214727.2600.282.camel@**damavand.mech.kth.se<1326214727.2600.282.camel at damavand.mech.kth.se>
>>>>>> Content-Type: text/plain; charset="UTF-8"
>>>>>> Dear Paul and Stefan;
>>>>>> Thanks very much for looking into it. I use polynomial order 7th
>>>>>> (lx1=8). For the coarse-grid solver I actually used XXt. I also tried to
>>>>>> use AMG, but unfortunately neither v619 nor the latest version could
>>>>>> have compiled its matlab files and always gives me this error (in
>>>>>> matlab/R2011a):
>>>>>> sparsification tolerance [1e-4]: stol = 0.0001
>>>>>>       Segmentation violation detected at Tue Jan 10 15:56:46 2012
>>>>>> Abnormal termination:
>>>>>> I have been in the web page: "amg_matlab Matlab based tool to generate
>>>>>> AMG solver inputfiles" (http://nek5000.mcs.anl.gov/**
>>>>>> index.php/Amg_matlab <http://nek5000.mcs.anl.gov/index.php/Amg_matlab>)
>>>>>> which gives me an empty link.
>>>>>> I had an old version of the .dat files needed to run AMG, which I tried
>>>>>> those as (amg_Aff.dat, amgdmp_i.dat, amg.dat, amg_AfP.dat, amgdmp_p.dat,
>>>>>> amgdmp_j.dat, amg_W.dat) and I have got this error:
>>>>>> AMG: reading through row 142800, pass 119/121
>>>>>> AMG: reading through row 144000, pass 120/121
>>>>>> ERROR (proc
>>>>>> 0000,
>>>>>> /afs/pdc.kth.se/home/a/**anoorani/codes/latest_nek/**
>>>>>> nek5_svn/trunk/nek/jl/amg.c:**468<http://pdc.kth.se/home/a/anoorani/codes/latest_nek/nek5_svn/trunk/nek/jl/amg.c:468>
>>>>>> AMG: missing data for some
>>>>>> rows
>>>>>> I think AMG could be a possibility to overcome this problem, though I
>>>>>> could not manage to get a run with that one. I look into the problem
>>>>>> with higher polynomial order to see if it reduces the number of elements
>>>>>> dramatically, or at least resolve this issue.
>>>>>> Best regards
>>>>>> Azad
>>>>>>> Hi Azad,
>>>>>>> -Stefan
>>>>>>> On 1/10/12, nek5000-users at lists.mcs.anl.gov
>>>>>>> Hi Azad,
>>>>>>> Paul
>>>>>>> On Tue, 10 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Dear NEKs;
>>>>>>> the last stage:
>>>>>>> mg_nx:            1            3
>>>>>>> mg_ny:            1            3
>>>>>>> mg_nz:            1            3
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>> call usrsetvert
>>>>>>> done :: usrsetvert
>>>>>>> Many thanks
>>>>>>> Azad
>>>>>> End of Nek5000-users Digest, Vol 35, Issue 5
>>>>> This message was sent using IMP, the Internet Messaging Program.
>>>> End of Nek5000-users Digest, Vol 35, Issue 7
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120112/b0da596a/attachment.htm>
>> End of Nek5000-users Digest, Vol 35, Issue 9
> Message: 2
> Date: Thu, 12 Jan 2012 15:12:23 -0600
> Message-ID:
> 	<CAFTrYW+X0-OzBXRySZBViYG_FcWcm0neddJV1MJ9rbyxj+6GSA at mail.gmail.com>
> Hi Azad,
> This error means that your version of matlab doesn't like the fprint() in
> coarse_par.f, line 37.
> Since this is just a print statement, you can comment this out by adding %
> in front of line 37.  So it should look like:
> %      fprintf(1,'%g\n',max(lanczos(sparse(D*S*D))));
> Then this should work, at least for turbChannel.
> good luck,
> Katie
> On Thu, Jan 12, 2012 at 2:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Katie;
>> Thanks for updating the page. I did exactly the same as it's suggested in
>> the updated page. After ./run of the script in amg_matlab I got this error:
>> Level 6, dim(A) = 2
>> I tried it for turbChannel test case as well as some other simplified test
>> Regards
>> Azad
>> Quoting
>>> Today's Topics:
>>> Message: 1
>>> Message-ID:
>>>        <CAFTrYW+**ctDhLYVdJCh8mOpA6bB7j361o=vn7W**
>>> aATYkEDCifYsw at mail.gmail.com <vn7WaATYkEDCifYsw at mail.gmail.com>>
>>> Hi Azad,
>>> the
>>> what
>>> thanks,
>>> Katie
>>> <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>>
>>> wrote:
>>>  Hi Stefan;
>>>> not
>>>> AMG: 144540 rows
>>>> ERROR (proc 0000, /scratch/azad/codes/late/nek5_**
>>>> AMG: data
>>>> Regards
>>>> Azad
>>>> Quoting nek5000-users-request at lists.****mcs.anl.gov <http://mcs.anl.gov>
>>>> <nek5000-users-**request at lists.mcs.anl.gov<nek5000-users-request at lists.mcs.anl.gov>
>>>>>       nek5000-users at lists.mcs.anl.****gov<nek5000-users at lists.mcs.**
>>>>> anl.gov <nek5000-users at lists.mcs.anl.gov>>
>>>>> https://lists.mcs.anl.gov/****mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users>
>>>>> **<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>>>       nek5000-users-request at lists.****mcs.anl.gov <http://mcs.anl.gov><
>>>>>       nek5000-users-owner at lists.mcs.****anl.gov<nek5000-users-owner@**
>>>>> lists.mcs.anl.gov <nek5000-users-owner at lists.mcs.anl.gov>>
>>>>> Today's Topics:
>>>>>  1. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.***
>>>>> *gov<nek5000-users at lists.mcs.**anl.gov<nek5000-users at lists.mcs.anl.gov>
>>>>> Message: 1
>>>>> From: nek5000-users at lists.mcs.anl.****gov <nek5000-users at lists.mcs.anl.
>>>>> To: nek5000-users at lists.mcs.anl.****gov <nek5000-users at lists.mcs.anl.**
>>>>> Message-ID:
>>>>>       <**CAGTrLsaGQkuowxvfpK3AxvCtgCEk****as9YBJkX024qF2Sh7RcmdA at mail.*
>>>>> gmail.com<CAGTrLsaGQkuowxvfpK3**AxvCtgCEkas9YBJkX024qF2Sh7Rcmd**
>>>>> A at mail.gmail.com<CAGTrLsaGQkuowxvfpK3AxvCtgCEkas9YBJkX024qF2Sh7RcmdA at mail.gmail.com>
>>>>> Hi Azad,
>>>>> Stefan
>>>>> On 1/11/12, nek5000-users at lists.mcs.anl.****gov<
>>>>> nek5000-users at lists.mcs.**anl.gov <nek5000-users at lists.mcs.anl.gov>>
>>>>> <nek5000-users at lists.mcs.anl.****gov
>>>>>> correct AMG scheme.
>>>>>> Many thanks
>>>>>> Azad
>>>>>>  Hi Azad,
>>>>>>> Best.
>>>>>>> Aleks
>>>>>>> Hi Azad,
>>>>>>> index.php/Amg_matlab <https://nek5000.mcs.anl.gov/**
>>>>>>> index.php/Amg_matlab<https://nek5000.mcs.anl.gov/index.php/Amg_matlab>
>>>>>>> -Stefan
>>>>>>> Quoting nek5000-users-request at lists.****mcs.anl.gov<http://mcs.anl.gov>
>>>>>>> *lists.mcs.anl.gov <nek5000-users-owner at lists.mcs.anl.gov>>
>>>>>>> Today's Topics:
>>>>>>> gov <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>>>>>>  2. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.***
>>>>>>>  3. Re: run-time hang up in gs_setup (nek5000-users at lists.mcs.anl.***
>>>>>>> Message: 1
>>>>>>> From: nek5000-users at lists.mcs.anl.****gov<nek5000-users at lists.mcs.**
>>>>>>> Message-ID: <Pine.LNX.4.64.1201100557250.****6026 at v8.mcs.anl.gov<
>>>>>>> Pine.LNX.**4.64.1201100557250.6026 at v8.**mcs.anl.gov<Pine.LNX.4.64.1201100557250.6026 at v8.mcs.anl.gov>
>>>>>>> Hi Azad,
>>>>>>> Paul
>>>>>>> On Tue, 10 Jan 2012, nek5000-users at lists.mcs.anl.****gov<
>>>>>>> >wrote:
>>>>>>>  Dear NEKs;
>>>>>>>> pipe
>>>>>>>> with
>>>>>>>> in
>>>>>>>> the last stage:
>>>>>>>> mg_nx:            1            3
>>>>>>>> mg_ny:            1            3
>>>>>>>> mg_nz:            1            3
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> Many thanks
>>>>>>>> Azad
>>>>>>> Message: 2
>>>>>>> Message-ID:
>>>>>>>       <**CAGTrLsaexkteQN1Y1NQ3FYz7Q2ab***
>>>>>>> *b5YSLzOv+zeTwdvYXpD3Fw at mail.****
>>>>>>> gmail.com<CAGTrLsaexkteQN1Y1NQ**3FYz7Q2abb5YSLzOv%**
>>>>>>> 2BzeTwdvYXpD3Fw at mail.gmail.com<CAGTrLsaexkteQN1Y1NQ3FYz7Q2abb5YSLzOv%252BzeTwdvYXpD3Fw at mail.gmail.com>
>>>>>>> Hi Azad,
>>>>>>> -Stefan
>>>>>>> On 1/10/12, nek5000-users at lists.mcs.anl.****gov<
>>>>>>> <nek5000-users at lists.mcs.anl.****gov <nek5000-users at lists.mcs.anl.**
>>>>>>> gov <nek5000-users at lists.mcs.anl.gov>>>
>>>>>>> wrote:
>>>>>>>> Hi Azad,
>>>>>>>> Paul
>>>>>>>> >wrote:
>>>>>>>>  Dear NEKs;
>>>>>>>>> pipe
>>>>>>>>> with
>>>>>>>>> in
>>>>>>>>> the last stage:
>>>>>>>>> mg_nx:            1            3
>>>>>>>>> mg_ny:            1            3
>>>>>>>>> mg_nz:            1            3
>>>>>>>>> call usrsetvert
>>>>>>>>> done :: usrsetvert
>>>>>>>>> call usrsetvert
>>>>>>>>> done :: usrsetvert
>>>>>>>>> call usrsetvert
>>>>>>>>> done :: usrsetvert
>>>>>>>>> Many thanks
>>>>>>>>> Azad
>>>>>>>>>  ______________________________****_________________
>>>>>>>> Nek5000-users at lists.mcs.anl.****gov <Nek5000-users at lists.mcs.anl.**
>>>>>>>> gov <Nek5000-users at lists.mcs.anl.gov>>
>>>>>>> Message: 3
>>>>>>> Message-ID:
>>>>>>> <1326214727.2600.282.camel@**d**amavand.mech.kth.se<http://damavand.mech.kth.se>
>>>>>>> <1326214727**.2600.282.camel at damavand.mech.**kth.se<1326214727.2600.282.camel at damavand.mech.kth.se>
>>>>>>> to
>>>>>>> matlab/R2011a):
>>>>>>> index.php/Amg_matlab <http://nek5000.mcs.anl.gov/**
>>>>>>> index.php/Amg_matlab<http://nek5000.mcs.anl.gov/index.php/Amg_matlab>
>>>>>>> tried
>>>>>>> amgdmp_p.dat,
>>>>>>> ERROR (proc
>>>>>>> 0000,
>>>>>>> /afs/pdc.kth.se/home/a/****anoorani/codes/latest_nek/**<http://pdc.kth.se/home/a/**anoorani/codes/latest_nek/**>
>>>>>>> nek5_svn/trunk/nek/jl/amg.c:****468<http://pdc.kth.se/home/a/**
>>>>>>> anoorani/codes/latest_nek/**nek5_svn/trunk/nek/jl/amg.c:**468<http://pdc.kth.se/home/a/anoorani/codes/latest_nek/nek5_svn/trunk/nek/jl/amg.c:468>
>>>>>>> rows
>>>>>>> elements
>>>>>>> Best regards
>>>>>>> Azad
>>>>>>>  Hi Azad,
>>>>>>>> -Stefan
>>>>>>>> Hi Azad,
>>>>>>>> Paul
>>>>>>>> Dear NEKs;
>>>>>>>> pipe
>>>>>>>> with
>>>>>>>> in
>>>>>>>> the last stage:
>>>>>>>> mg_nx:            1            3
>>>>>>>> mg_ny:            1            3
>>>>>>>> mg_nz:            1            3
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> call usrsetvert
>>>>>>>> done :: usrsetvert
>>>>>>>> Many thanks
>>>>>>>> Azad
>>>>>> <Nek5000-users at lists.mcs.anl.**gov<Nek5000-users at lists.mcs.anl.gov>
>>> URL: <http://lists.mcs.anl.gov/**pipermail/nek5000-users/**
>>> attachments/20120112/b0da596a/**attachment.htm<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120112/b0da596a/attachment.htm>
> URL:
> <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120112/0751c542/attachment.htm>
> End of Nek5000-users Digest, Vol 35, Issue 10
