[Nek5000-users] Restart problem
Thu Jan 5 03:13:14 CST 2012
Do you have any passive scalars?
There are some issues w.r.t passive scalar i/o that we're working
to resolve.
Paul
On Thu, 5 Jan 2012, nek5000-users at lists.mcs.anl.gov wrote:
> On Thu, 2011-12-22 at 22:22 -0600, nek5000-users at lists.mcs.anl.gov
> wrote:
> Hi
> Thank you Paul. I've made short test with jet in crossflow and it seem
> to work, but I've got sometimes following warning
> WARNING: restart file has a NSPCAL > LDIMT
> read only part of the fld-data!
> WARNING: NPSCAL read from restart file differs from
> currently used NPSCAL!
> What's strange this warning doesn't show up at every restart. I'm going
> to make some longer tests now.
> Regards
> Adam
>>> Hi
>>> I simulate jet in crossflow problem with nek5000 and I've got serius
>>> problems with restarting the simulation. It causes strong spurious
>>> velocity oscillation and I cannot get rid of them. I've implemented
>>> restarting procedure described in prepost.f, but it doesn't help much.
>>> Playing with file format (parameters p66, p67) and projection (p94, p95)
>>> I can only decrease oscillations amplitude, but they are still there.
>>> Surprisingly saving output files in double precision (p63=8) makes
>>> everything worse. Has anybody got similar problems?
>>> Best regards
>>> Adam
>> Hi,
>> I think that the full restart capability should now work with
>> the current version of the source.
>> There is a 2D example in the repo, with a README that I also
>> provide below.
>> Basically, you will now save 4 files each time you wish to
>> checkpoint.  The files come in two sets, A and B, and the A
>> set is then overwritten by the 3rd checkpoint, etc. so that
>> you have at most 8 checkpoint files on hand at any one time.
>> The files are 64 bit and thus cannot be used by VisIt --- thus,
>> they are truly designated as checkpoint/restart files and not
>> analysis files.   More information in the README below.
>> Please let me know if you have comments or questions.
>> Best regards,
>> Paul
>>> From the examples/cyl_restart directory:
>> SET UP:
>> This directory contains an example of full restart capabilities for
>> Nek5000.
>> The model flow is a von Karman street in the wake of a 2D cylinder.
>> The quantity of interest is taken to be the lift, which is monitored
>> via "grep agy logfile" in the run_test script.   A matlab file, doit.m,
>> can be used to analyze the output files containing the lift history
>> of the four cases.  The cases are:
>> ca   -   initial run (no projection)
>> cb   -   restart run for ca case
>> pa   -   initial run (with projection)
>> pb   -   restart run for pa case
>> BACKGROUND:
>> Timestepping in Nek5000 is based on BDFk/EXTk (k=3, typ.), which uses kth-order
>> backward-difference formulae (BDFk) to evaluate velocity time derivatives and
>> kth-order extrapolation (EXTk) for explicit evaluation of the nonlinear and
>> pressure boundary terms.  Under normal conditions, the velocity and pressure
>> for preceding timesteps are required to advance the the solution at each step.
>> At startup, the timestepper is typically bootstrapped using a lower-order
>> BDF/EXT formula that, given the artificiality of most initial conditions,
>> is typically adequate.    The velocity field often has enough inertia and
>> sufficient signature such that the same bootstrap procedure also works when
>> restarting from an existing solution (i.e., a .fnnnnn or .fldnn file, stored
>> in 32-bit precision).
>> For some cases, it is important to have reproducibility of the time history
>> to the working precision (14 digits, typ.) of the code.  The full restart
>> feature is designed to provide this capability.   The main features of
>> full restart are:
>> .Preserve alternating sets of snapshots (4 per set) in 64-bit precision.
>>   (Alternating sets are saved in case the job fails in the middle of
>>    saving a set.)
>> .Use the most recent set to restart the computation by overwriting
>>   the solution for the first steps, 0 through 3, with the preserved
>>   snapshots.
>> Full restart is triggered through the .usr file.    In the given example
>> cases, "ca" and "cb" the restart-save is illustrated in ca.usr and the
>> actual restart, plus the save, is illustrated in cb.usr.   For these cases,
>> the restart is encapsulated in the user-provided routine "my_full_restart"
>> shown below, along with the calling format in userchk:
>> c-----------------------------------------------------------------------
>>        subroutine userchk
>>        include 'SIZE'
>>        include 'TOTAL'
>>        logical if_drag_out,if_torq_out
>>        call my_full_restart
>>        scale = 1.
>>        if_drag_out = .true.
>>        if_torq_out = .false.
>>        call torque_calc(scale,x0,if_drag_out,if_torq_out)
>>        return
>>        end
>>        subroutine my_full_restart
>>        character*80 s80(4)
>>        call blank(s80,4*80)
>>        s80(1) ='rs8ca0.f00005'
>>        s80(2) ='rs8ca0.f00006'
>>        s80(3) ='rs8ca0.f00007'
>>        s80(4) ='rs8ca0.f00008'
>>        call full_restart(s80,4)  ! Will overload 5-8 onto steps 0-3
>>        iosave = iostep           ! Trigger save based on iostep
>>        call full_restart_save(iosave)
>>        return
>>        end
>> Note that in the example above, the set enumerated 5--8 is used to restart
>> the computation.   This set is generated by first running the "ca" case.
>> Note that the frequency of the restart output is coincident with the
>> standard output frequency of field files (snapshots).  This might be too
>> frequent if one is, say, making a movie where snapshots are typically
>> dumped every 10 steps.   It would make more sense in this case to set
>> iosave=1000, say.
>> Note also that if one is initiating a computation from something other
>> than the full restart mode then the full_restart() call should be commented
>> out.
>> COMMENTS:
>> Full reproducibility of the solution is predicated on having sufficient
>> history information to replicate the state of "a" when running "b".
>> While such replication is possible, it does preclude acceleration of the
>> iterative solvers by projection onto prior solution spaces [1,2], since
>> these projections typically retain relatively long sequences of information
>> (e.g., spanning tens of steps) to maximally extract all the regularity in the
>> solution history.   Consequently, _full_ reproducibility is not retained with
>> projection turned on.  In this case, the solution is reproduced only to the
>> tolerance of the iterative solvers, which is in any case the maximum level
>> of accuracy attainable in the solution.   To illustrate the difference,
>> we provide a test case pairing, "pa" and "pb", which is essentially the
>> same as the ca/cb pair save that projection is turned on for pa/pb.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
