[Nek5000-users] write initial condition
Tue Feb 28 13:44:44 CST 2012
Thanks Mike for the suggestion...
I often achieve this result via:
nekbmpi blah 32
echo 1 > ioinfo
which tells nek to dump on the next step, which, if timing
is good, should be the first.
You're right, however, that we should make it a more certain
thing.   I'll talk with the group here about what would be a
good flag to realize this.
Paul
On Tue, 28 Feb 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Paul & Josh,
> Thanks for your suggestions.  I should be set with those.
> Paul, the IC-output might make a nice flag in the .rea file.  There have been many instances where I've looked at my fld files thinking -- "what's up??"  -- and wondering how the initial conditions looked.
> Cheers,
> Mike
> On Feb 28, 2012, at 12:30 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Sorry - I now see your question..
>> The only thing I know of is to add the following to userchk:
>>       if (istep.eq.0) call outpost(vx,vy,vz,pr,t,'   ')
>> You need something slightly different if you have multiple
>> passive scalars.  (you need output2() ... check the source
>> for syntax.)
>> Paul
>>> set nsteps to 0 and fintime to 0 ?
>>>> Hello neks.
>>>> Is there a .rea flag or other simple solution to have nek write the
>>>> initial-condition fld file regardless of the p015 IOSTEP choice?
>>>> Thanks.
>>>> --Mike
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
