[Nek5000-users] 2D Axisymmetric in semi-circular annulus
Tue Aug 28 02:00:01 CDT 2012
Hi Adrian,
My suspicion is that the issue is somehow related to
the SYM bc + curve sides + ifaxis.   Generally, SYM on
curve sides implies using the stress formulation.
At present, I'm not certain of the status of the
combination:
IFSTRS  T
IFAXIS  T
We can look into this as well.
Sorry that this has been holding you up.
Paul
On Mon, 27 Aug 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Nek users,
> I have been attempting to set up a 2D axisymmetric problem with an azimuthal
> velocity, in a semi-circular annulus container (the 2D axisymmetric version
> of a spherical shell), but have encountered problems with the terms evolving
> the azimuthal velocity blowing up near to the axis, and wondered if anybody
> would be able to help with this?
> I have looked at the vortex2 example, and have copied the relevant aspects to
> my .usr and .rea files. I have set IFAXIS=T to get the correct viscous
> operators for cylindrical geometry where (x,y)->(z,R), as well as IFHEAT=T,
> IFAZIV=T, using temperature as the azimuthal velocity.  My test mesh is
> created using prenek, and contains 4 elements on a polar grid from r=0.5 to 1
> and theta=0 to 180. Since elements 2 & 4 have one side touching the R=0 (y=0)
> axis, I have used "A" boundary conditions, which are applied to side 1 for
> each of these elements, as is required. The remaining BCs are 'SYM' and 'I'
> for all of the exterior sides. The .rea file containing the mesh with 4
> elements is attached to this email. (In the SIZE file I have set
> lx1=20,lxd=30,lx2=lx1-2).
> For a simple test, if I set the initial conditions to be a uniform rotation
> about the z-axis (setting temp = y), within several time-steps the code blows
> up, giving NaN's for each quantity (I have tested various initial conditions,
> which each give the same error). The line of code that appears to cause
> problems is the line ~240 of hmholtz.f, TERM1 =
> BM1(I,J,1,IEL)*U(I,J,1,IEL)/YM1(I,J,1,IEL)**2,
> since, when this term is set to 0, the code does not produce NaN's. (Though
> the viscous operator for the azimuthal velocity is then incorrect...)
> When IFHEAT=IFAZIV=F,  i.e. when I am not integrating the
> temperature/azimuthal velocity, the code runs without problem on the same
> mesh.
> I am wondering if there is a problem with how I have set up the mesh that
> causes this problem? And if so, is there a way to fix this?
> Thanks,
> Adrian
> Modifications to .usr file are:
> c-----------------------------------------------------------------------
>      subroutine userf  (ix,iy,iz,eg)
>      include 'SIZE'
>      include 'TOTAL'
>      include 'NEKUSE'
>      integer e,f,eg
>      if(y.gt.0) ffy = temp*temp/y
>      return
>      end
>      subroutine userq  (ix,iy,iz,eg)
>      include 'SIZE'
>      include 'TOTAL'
>      include 'NEKUSE'
>      integer e,f,eg
>      if(y.gt.0) then
>        visc = param(2)
>        qvol = -uy*temp/y
>      endif
>      return
>      end
>      subroutine useric (ix,iy,iz,ieg)
>      include 'SIZE'
>      include 'TOTAL'
>      include 'NEKUSE'
>      temp = y
>      return
>      end
> My .rea file:
> ****** PARAMETERS *****
>   2.610000      NEKTON VERSION
>           2  DIMENSIONAL RUN
>         118  PARAMETERS FOLLOW
>   1.00000     p001 DENSITY
>  0.10000E-06 p002 VISCOS
>   0.00000     p003
>   1.00000     p004
>   0.00000     p005
>   0.00000     p006
>   1.00000     p007 RHOCP
>  0.100000E-06 p008 CONDUCT
>   0.00000     p009
>   0.00000     p010 FINTIME
>  0.100000E+08 p011 NSTEPS
>  0.100000E-03 p012 DT
>   0.00000     p013 IOCOMM
>   0.00000     p014 IOTIME
>   1000.00     p015 IOSTEP
>   0.00000     p016 PSSOLVER: 0=default
>   1.00000     p017
>  0.500000E-01 p018 GRID < 0 --> # cells on screen
>  -1.00000     p019 INTYPE
>   5.00000     p020 NORDER
>  0.100000E-06 p021 DIVERGENCE
>  0.100000E-08 p022 HELMHOLTZ
>   0.00000     p023 NPSCAL
>  0.100000E-01 p024 TOLREL
>  0.100000E-01 p025 TOLABS
>  0.450000     p026 COURANT/NTAU
>   3.00000     p027 TORDER
>   1.00000     p028 TORDER: mesh velocity (0: p28=p27)
>   0.00000     p029 = magnetic visc if > 0, = -1/Rm if < 0
>   0.00000     p030 > 0 ==> properties set in uservp()
>   0.00000     p031 NPERT: #perturbation modes
>   0.00000     p032 #BCs in re2 file, if > 0
>   0.00000     p033
>   0.00000     p034
>   0.00000     p035
>   0.00000     p036
>   0.00000     p037
>   0.00000     p038
>   0.00000     p039
>   0.00000     p040
>   0.00000     p041 1-->multiplicative SEMG
>   0.00000     p042 0=gmres/1=pcg
>   0.00000     p043 0=semg/1=schwarz
>   0.00000     p044 0=E-based/1=A-based prec.
>   0.00000     p045 Relaxation factor for DTFS
>   0.00000     p046 reserved
>   0.00000     p047 vnu: mesh matieral prop.
>   0.00000     p048
>   0.00000     p049
>   0.00000     p050
>   0.00000     p051
>   0.00000     p052 IOHIS
>   0.00000     p053
>   0.00000     p054 fixed flow rate dir: |p54|=1,2,3=x,y,z
>   0.00000     p055 vol.flow rate (p54>0) or Ubar (p54<0)
>   0.00000     p056
>   0.00000     p057
>   0.00000     p058
>   0.00000     p059 !=0 --> full Jac. eval. for each el.
>   0.00000     p060 !=0 --> init. velocity to small nonzero
>   0.00000     p061
>   0.00000     p062 >0 --> force byte_swap for output
>   0.00000     p063 =8 --> force 8-byte output
>   0.00000     p064 =1 --> perturbation restart
>   0.00000     p065 #iofiles (eg, 0 or 64); <0 --> sep. dirs
>   0.00000     p066 output : <0=ascii, else binary
>   0.00000     p067 restart: <0=ascii, else binary
>   0.00000     p068 iastep: freq for avg_all (0=iostep)
>   0.00000     p069
>   0.00000     p070
>   0.00000     p071
>   0.00000     p072
>   0.00000     p073
>   0.00000     p074 verbose Helmholtz
>   0.00000     p075
>   0.00000     p076
>   0.00000     p077
>   0.00000     p078
>   0.00000     p079
>   0.00000     p080
>   0.00000     p081
>   0.00000     p082
>   0.00000     p083
>   0.00000     p084 !=0 --> sets initial timestep if p12>0
>   0.00000     p085 dt ratio if p84 !=0, for timesteps>0
>   0.00000     p086 reserved
>   0.00000     p087
>   0.00000     p088
>   0.00000     p089
>   0.00000     p090
>   0.00000     p091
>   0.00000     p092
>   20.0000     p093 Number of previous pressure solns saved
>   5.00000     p094 start projecting velocity after p94 step
>   5.00000     p095 start projecting pressure after p95 step
>   0.00000     p096
>   0.00000     p097
>   0.00000     p098
>   3.00000     p099 dealiasing: <0--> off/3--> old/4--> new
>   0.00000     p100
>   0.00000     p101 Number of additional modes to filter
>   1.00000     p102 Dump out divergence at each time step
>  0.100000E-01 p103 weight of stabilizing filter (.01)
>   0.00000     p104
>   0.00000     p105
>   0.00000     p106
>   0.00000     p107 !=0 --> add to h2 array in hlmhotz eqn
>   0.00000     p108
>   0.00000     p109
>   0.00000     p110
>   0.00000     p111
>   0.00000     p112
>   0.00000     p113
>   0.00000     p114
>   0.00000     p115
>   0.00000     p116 !=0: x elements for fast tensor product
>   0.00000     p117 !=0: y elements for fast tensor product
>   0.00000     p118 !=0: z elements for fast tensor product
>      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
>   0.00000       0.00000       0.00000       0.00000       0.00000
>          12   LOGICAL SWITCHES FOLLOW
> T     IFFLOW
> T     IFHEAT
> T     IFTRAN
> T T F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
> F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
> T     IFAXIS
> T     IFAZIV
> T     IFSTRS
> F     IFMGRID
> F     IFMODEL
> F     IFKEPS
> F     IFCHAR
>   10.0000       10.0000      -4.00000      -5.50000     XFAC,YFAC,XZERO,YZERO
> **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
>         4         2         4 NEL,NDIM,NELV
>      ELEMENT          1 [    1C]    GROUP     0
> -0.4371138E-07 -0.2185569E-07  0.3535533      0.7071066
>   1.000000      0.5000000      0.3535533      0.7071066
>      ELEMENT          2 [    1D]    GROUP     0
>  0.5000000       1.000000      0.7071066      0.3535533
>   0.000000       0.000000      0.7071066      0.3535533
>      ELEMENT          3 [    1D]    GROUP     0
>  0.5962440E-08  0.1192488E-07 -0.7071066     -0.3535533
>      ELEMENT          4 [    1 ]    GROUP     0
>  -1.000000     -0.5000000     -0.3535533     -0.7071066
>  0.8742278E-07  0.4371139E-07  0.3535533      0.7071066
>  ***** CURVED SIDE DATA *****
>         8 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
>  2  1 -0.500000       0.00000       0.00000       0.00000       0.00000     C
>  4  1   1.00000       0.00000       0.00000       0.00000       0.00000     C
>  2  2   1.00000       0.00000       0.00000       0.00000       0.00000     C
>  4  2 -0.500000       0.00000       0.00000       0.00000       0.00000     C
>  2  3   1.00000       0.00000       0.00000       0.00000       0.00000     C
>  4  3 -0.500000       0.00000       0.00000       0.00000       0.00000     C
>  2  4 -0.500000       0.00000       0.00000       0.00000       0.00000     C
>  4  4   1.00000       0.00000       0.00000       0.00000       0.00000     C
>  ***** BOUNDARY CONDITIONS *****
>  ***** FLUID   BOUNDARY CONDITIONS *****
> E    1  1   3.00000       1.00000       0.00000       0.00000       0.00000
> SYM  1  2   0.00000       0.00000       0.00000       0.00000       0.00000
> E    1  3   2.00000       3.00000       0.00000       0.00000       0.00000
> SYM  1  4   0.00000       0.00000       0.00000       0.00000       0.00000
> A    2  1   0.00000       0.00000       0.00000       0.00000       0.00000
> SYM  2  2   0.00000       0.00000       0.00000       0.00000       0.00000
> E    2  3   1.00000       3.00000       0.00000       0.00000       0.00000
> SYM  2  4   0.00000       0.00000       0.00000       0.00000       0.00000
> E    3  1   1.00000       1.00000       0.00000       0.00000       0.00000
> SYM  3  2   0.00000       0.00000       0.00000       0.00000       0.00000
> E    3  3   4.00000       3.00000       0.00000       0.00000       0.00000
> SYM  3  4   0.00000       0.00000       0.00000       0.00000       0.00000
> A    4  1   0.00000       0.00000       0.00000       0.00000       0.00000
> SYM  4  2   0.00000       0.00000       0.00000       0.00000       0.00000
> E    4  3   3.00000       3.00000       0.00000       0.00000       0.00000
> SYM  4  4   0.00000       0.00000       0.00000       0.00000       0.00000
>  ***** THERMAL BOUNDARY CONDITIONS *****
> I    1  2   0.00000       0.00000       0.00000       0.00000       0.00000
> I    1  4   0.00000       0.00000       0.00000       0.00000       0.00000
> I    2  2   0.00000       0.00000       0.00000       0.00000       0.00000
> I    2  4   0.00000       0.00000       0.00000       0.00000       0.00000
> I    3  2   0.00000       0.00000       0.00000       0.00000       0.00000
> I    3  4   0.00000       0.00000       0.00000       0.00000       0.00000
> I    4  2   0.00000       0.00000       0.00000       0.00000       0.00000
> I    4  4   0.00000       0.00000       0.00000       0.00000       0.00000
>           0  PRESOLVE/RESTART OPTIONS  *****
>           7          INITIAL CONDITIONS *****
> C Default
> C Default
> C Default
> C Default
> C Default
> C Default
> C Default
>  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
>           4                  Lines of Drive force data follow
> C
> C
> C
> C
>  ***** Variable Property Data ***** Overrrides Parameter data.
>           1  Lines follow.
>           0  PACKETS OF DATA FOLLOW
>  ***** HISTORY AND INTEGRAL DATA *****
>           0    POINTS.  Hcode, I,J,H,IEL
>  ***** OUTPUT FIELD SPECIFICATION *****
>           6  SPECIFICATIONS FOLLOW
> T       COORDINATES
> T       VELOCITY
> T       PRESSURE
> T       TEMPERATURE
> F       TEMPERATURE GRADIENT
>           0       PASSIVE SCALARS
>  ***** OBJECT SPECIFICATION *****
>       0 Surface Objects
>       0 Volume  Objects
>       0 Edge    Objects
>       0 Point   Objects
> Nek5000-users mailing list
