[Nek5000-users] CUBIT/Moab
Tue Sep 20 13:50:02 CDT 2011
I sent these instructions to a different Nek user a few days back:
Ok.  I think in the repo version of Nek, you have to name your mesh input "input.h5m", which you get by translating from
.cub to .h5m (the latter is the hdf5-based native file representation MOAB uses).  If you want to run this in parallel,
you also need to run a partitioner on the file (using tools/mbzoltan in moab), and change the code at the beginning of
nek/3rd_party/moab.f, nekMOAB_load subroutine, to use PARTITION=PARALLEL_PARTITION option.  Finally, you'll need to
change the value used for lelt in the SIZE file (set it to the number of elements in the mesh).
- tim
On 09/20/2011 01:39 PM, Aleksandr Obabko wrote:
> Hi Josh,
> I have been told that the way to convert .cub file into MOAB's native .h5m file is using mbconvert utility which should be in MOAB's bin directory.
> (https://svn.mcs.anl.gov/repos/ITAPS/MOAB/tags/preVersion4.0/README.IO).
> Please, try
> mbconvert blah.cub blah.h5m
> Best,
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users"<nek5000-users at lists.mcs.anl.gov>
> Sent: Monday, September 19, 2011 12:33:44 PM
> Subject: [Nek5000-users] CUBIT/Moab
> Neks,
> We are interested in using CUBIT meshes in our Nek runs.  I took a
> look at the "moab" example in the source, but I'm still unsure of the
> proper process of getting a CUBIT-generated mesh into Nek.
> I have created a CUBIT mesh (.cub), and have also downloaded,
> compiled, and installed MOAB.  I see in the example that a .h5m file
> is used (the native format of MOAB), but I don't know how to generate
> it through MOAB (from my .cub file).
> I realize that this is probably more of a MOAB question than a Nek
> question, but are there some simple instructions/examples to help me
> in understanding how to use a CUBIT mesh in Nek?  Any help would be
> appreciated!
> Thanks,
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
