[Nek5000-users] Generating a 2D circular mesh
Tue Sep 13 09:24:06 CDT 2011
Hello all.   Just to add bit, I had the same problem as David with genbox.
--Mike
On Sep 10, 2011, at 9:45 AM, <nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi David,
> It's been awhile since I tested this option in genbox.
> I would suggest the alternative route of simply
> wrapping the box geometry in usrdat2, as is done
> for the 2D Taylor Couette example in
>    nek5_svn/examples/Taylor
> Please let me know if that approach works for you.
> Paul
> On Sat, 10 Sep 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I'm having a little trouble with my first foray into circular geometries. I
>> tried to construct a 2D annular mesh using genbox with the following .box
>> file:
>> an.rea
>> 2                     spatial dimension
>> 2                     number of fields
>> Y
> vi
>> -4  -12          nelr,nel_theta
>> 0 0              x0 y0
>> ccbb
>> 1 2 1
>> 0 1 1
>> SYM,SYM,         V bc's  ! NB:  3 characters each !
>> f  ,f  ,         T bc's  !      You must have 2 spaces!!
>> genbox seems to work properly, with the exception of the fact that nothing
>> after the boundary data gets copied over from the old .rea file.  Nonethess,
>> I copy that chunk over manually and run nek5000, which exits with the
>> following error:
>> WARNINGa: Detected non-right-handed element.
>> Number       1  C1-4:  0.6667E+00  0.8333E+00 -0.2083E+00 -0.4167E-01
>> Any guidance would be much appreciated.
>> Best,
>> David
> Nek5000-users mailing list
