[Nek5000-users] Pressure Normalization
Thu Oct 20 05:25:45 CDT 2011
Hi Azad,
Any constant can be added to p in the case you describe.
Consequently, we choose the constant such that the spatial
average of p is zero at each timestep.
Does this answer your question?
Paul
On Thu, 20 Oct 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks;
> I would like to know how the pressure normalization is done in the
> code. Since I'm running a turbulent pipe flow with periodic B.C.s using
> Pn_Pn-2 scheme, I would like to obtain P_rms values; however, the
> pressure fluctuations does not look alright. I think in case of
> inflow/outflow, the conditions are to set the pressure to be zero
> at these boundaries; obviously this is not possible for periodic cases.
> Many thanks;
> Azad
> Nek5000-users mailing list
