[Nek5000-users] Error when running the vortex problem
Tue Oct 11 14:58:29 CDT 2011
Can you post your r1854a.usr .
-Stefan
On 10/11/11, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Dong,
> which fortran compiler are you using ? (also, which C compiler?)
> Paul
> On Tue, 11 Oct 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> PS --
>> It should look like
>> gs_setup: 0 unique labels shared
>> done :: setup h1 coarse grid   6.9365978240966797E-002 sec
>> call usrdat3
>> done :: usrdat3
>> set initial conditions
>> Checking restart options: r1492_n08.fld27 time=0.
>> Reading checkpoint data
>> byte swap: F   6.543210     -2.9312772E+35
>> Read mode:    4.000000000000000 neltr,nxr,nyr,nzr:      140   8   8   8
>>  Restarting from file r1492_n08.fld27
>>  Columns for restart data U,V,W,P,T,S,N:    0   2   3   4   0   0   4
>> Reading           1
>>  Successfully read data from dump number  1.
>>> Hi, Paul.
>>> Thanks for the reply.
>>> Yeah. I was compiling the code in the examples/vortex directory. The
>>> difference is that it is the file "r1854a.usr" included, not "r1854.usr".
>>> But, even in the file "r1854a.usr", the "param(66)=4" is already well
>>> set.
>>> I am still trying to figure out why my run follows a different file
>>> format.
>>> Your further suggestion is very welcome.
>>> BTW, my platform is Linux/gnu.
>>> Thanks.
>>> -Dong
>>> -----Original Message-----
>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>> [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of
>>> Sent: Tuesday, October 11, 2011 3:03 PM
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: Re: [Nek5000-users] Error when running the vortex problem
>>> Hi Dong,
>>> For some reason, your run is traversing the .f00000 file format
>>> branch, rather than the .fld input branch.
>>> This traversal is generally controlled by setting
>>> param(66)=4 (for .fld) in usrdat2 (or usrdat) in the .usr file.
>>> I'm wondering if you are compiling with r1854.usr provided in
>>> the examples/vortex directory?
>>> Paul
>>>> Hi Dong,
>>>> What kind of platform are you running on?
>>>> Can you do an svn update in the example directory, just in case
>>>> the file was contaminated on transfer?
>>>> Paul
>>>>> Hi, Stefan.
>>>>> Sure. Attached is the log file.
>>>>> -Dong
>>>>> Sent: Tuesday, October 11, 2011 2:15 PM
>>>>> Please post a full log file. Note the file size is limited to 100KB.
>>>>> -Stefan
>>>>> On 10/11/11, S K <stgeke at googlemail.com> wrote:
>>>>>> Hi Dong,
>>>>>> It works for me. Did you change anything?
>>>>>> -Stefan
>>>>>>> Hi,
>>>>>>> I was trying to run nek5000 with vortex, following the default user
>>>>>>> setting.
>>>>>>> There is no problem for building, however when I start to run the
>>>>>>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>>>>>>> following
>>>>>>> is the related error report.
>>>>>>>        0       0 OPEN: r1492_n08.fld27
>>>>>>> byte swap: T   0.000000       0.000000
>>>>>>> 140   8   8   8 5.0101000E+0250101 U P                             4
>>>>>>> NELT,NX,N
>>>>>>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>>>>>>>                           NONSTD HDR, parse_hdr, abort.
>>>>>>> I briefly read the code. It looks like the code is reading the
>>>>>>> checkpoint
>>>>>>> file "r1492_n08.fld27" and there is something wrong with the file
>>>>>>> header.
>>>>>>> The file header does not follow the standard format and the code
>>>>>>> cannot
>>>>>>> understand the file.
>>>>>>> How can I solve this problem?
>>>>>>> Thank you.
>>>>>>> -Dong
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Hi, Stefan.
>>>> -Dong
>>>> -Stefan
>>>>> Hi Dong,
>>>>> -Stefan
>>>>>> Hi,
>>>>>> setting.
>>>>>> following
>>>>>> NELT,NX,N
>>>>>> checkpoint
>>>>>> header.
>>>>>> cannot
>>>>>> Thank you.
>>>>>> -Dong
