[Nek5000-users] Error when running the vortex problem
Tue Oct 11 14:36:40 CDT 2011
PS --
It should look like
gs_setup: 0 unique labels shared
  done :: setup h1 coarse grid   6.9365978240966797E-002 sec
  call usrdat3
  done :: usrdat3
  set initial conditions
  Checking restart options: r1492_n08.fld27 time=0.
  Reading checkpoint data
  byte swap: F   6.543210     -2.9312772E+35
  Read mode:    4.000000000000000
neltr,nxr,nyr,nzr:      140   8   8   8
   Restarting from file r1492_n08.fld27
   Columns for restart data U,V,W,P,T,S,N:    0   2   3   4   0   0   4
  Reading           1
   Successfully read data from dump number  1.
On Tue, 11 Oct 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi, Paul.
> Thanks for the reply.
> Yeah. I was compiling the code in the examples/vortex directory. The difference is that it is the file "r1854a.usr" included, not "r1854.usr". But, even in the file "r1854a.usr", the "param(66)=4" is already well set.
> I am still trying to figure out why my run follows a different file format. Your further suggestion is very welcome.
> BTW, my platform is Linux/gnu.
> Thanks.
> -Dong
> -----Original Message-----
> From: nek5000-users-bounces at lists.mcs.anl.gov [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, October 11, 2011 3:03 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Error when running the vortex problem
> Hi Dong,
> For some reason, your run is traversing the .f00000 file format
> branch, rather than the .fld input branch.
> This traversal is generally controlled by setting
> param(66)=4 (for .fld) in usrdat2 (or usrdat) in the .usr file.
> I'm wondering if you are compiling with r1854.usr provided in
> the examples/vortex directory?
> Paul
>> Hi Dong,
>> What kind of platform are you running on?
>> Can you do an svn update in the example directory, just in case
>> the file was contaminated on transfer?
>> Paul
>>> Hi, Stefan.
>>> Sure. Attached is the log file.
>>> -Dong
>>> Sent: Tuesday, October 11, 2011 2:15 PM
>>> Please post a full log file. Note the file size is limited to 100KB.
>>> -Stefan
>>> On 10/11/11, S K <stgeke at googlemail.com> wrote:
>>>> Hi Dong,
>>>> It works for me. Did you change anything?
>>>> -Stefan
>>>> On 10/11/11, nek5000-users at lists.mcs.anl.gov
>>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> Hi,
>>>>> I was trying to run nek5000 with vortex, following the default user
>>>>> setting.
>>>>> There is no problem for building, however when I start to run the
>>>>> application, there is an error "NONSTD HDR, parse_hdr, abort". The
>>>>> following
>>>>> is the related error report.
>>>>>        0       0 OPEN: r1492_n08.fld27
>>>>> byte swap: T   0.000000       0.000000
>>>>> 140   8   8   8 5.0101000E+0250101 U P                             4
>>>>> NELT,NX,N
>>>>> úaÃ@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
>>>>>                           NONSTD HDR, parse_hdr, abort.
>>>>> I briefly read the code. It looks like the code is reading the checkpoint
>>>>> file "r1492_n08.fld27" and there is something wrong with the file header.
>>>>> The file header does not follow the standard format and the code cannot
>>>>> understand the file.
>>>>> How can I solve this problem?
>>>>> Thank you.
>>>>> -Dong
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Hi, Stefan.
>> -Dong
>> -Stefan
>>> Hi Dong,
>>> -Stefan
>>>> Hi,
>>>> setting.
>>>> following
>>>> NELT,NX,N
>>>> Thank you.
>>>> -Dong
