[Nek5000-users] NEK gets stuck
Mon Oct 10 12:40:06 CDT 2011
Hi Stefan,
The machine is up now and I checked for the memory usage. The RAM usage is
well within the installed memory. The same problem occurs even with power of
two processors.
How does one toggle the multigrid solver?
Mani
> On Sun, Oct 9, 2011 at 11:39 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Mani,
>> What's your memory footprint? Any chance that you run out of memory?
>> Did you try to run the same setup on a power of two processors? What
>> happens if you disable the multigrid solver?
>> Cheers,
>> Stefan
>> On 10/8/11, nek5000-users at lists.mcs.anl.gov
>> > Dear Nek devs,
>> > I'm having trouble with a run involving a box with dimensions 5:5:1
>> > (length:breadth:height), for which I would like to go to a Rayleigh
>> number
>> > of 10^8. I generated the grid (.rea and .map) using the attached .box
>> file,
>> > but the run gets stuck at the point shown in the attached log.
>> > What could be the reason that NEK is stuck at that point? I suspect it
>> has
>> > something to do with the grid or the .map file.
>> > Thanks,
>> > Mani
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20111010/536d777a/attachment.html>
