[Nek5000-users] Error while postprocessing
Sat Mar 19 04:41:00 CDT 2011
No problem - happy to help!
On Sat, 19 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
>    Thanks, that did it! Sorry for the bother.
> Regards,
> Mani chandra
> On 03/19/2011 03:01 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Mani,
>> One thing I see is that the .usr file has only 9999
>> filenames declared, so you likely have a memory overwrite
>> once you exceed this number of files.
>> Can you check if this resolves your problem?
>> Best regards,
>> Paul
>>> Dear Nek devs,
>>>      I get the following error while trying to load .f000* field files
>>> into Nek for post processing. I noticed that this happens only when
>>> file.list has a large number of entries, in my case about 25000.
>>> call userchk
>>>   set initial conditions
>>>   Checking restart options: high_ray0.f00001
>>>   Reading checkpoint data
>>>         0       0 OPEN: high_ray0.f00001
>>> byte_read() :: can't fread after fwriting!
>>> I have attached the log, file.list, .usr and SIZE files.
>>> Thanks,
>>> Mani chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
