[Nek5000-users] Error while postprocessing
Sat Mar 19 04:31:52 CDT 2011
Hi Mani,
One thing I see is that the .usr file has only 9999
filenames declared, so you likely have a memory overwrite
once you exceed this number of files.
Can you check if this resolves your problem?
Best regards,
Paul
> Dear Nek devs,
>      I get the following error while trying to load .f000* field files
> into Nek for post processing. I noticed that this happens only when
> file.list has a large number of entries, in my case about 25000.
> call userchk
>   set initial conditions
>   Checking restart options: high_ray0.f00001
>   Reading checkpoint data
>         0       0 OPEN: high_ray0.f00001
> byte_read() :: can't fread after fwriting!
> I have attached the log, file.list, .usr and SIZE files.
> Thanks,
> Mani chandra
