[Nek5000-users] Restart with geometry changes
Fri Mar 11 07:15:08 CST 2011
Hi Markus,
I wonder whether to restart your solution from blah.fld without geometry -- say only velocity, pressure and temperature --  you can just set in .rea file
blah.fld U P T
Could you try that first?
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, March 10, 2011 10:03:41 PM
Subject: [Nek5000-users] Restart with geometry changes
Howdy Neks,
I ran a simulation on a certain geometry, saved solution files and would
now like to restart the same run from a given time step. The difference
is that I have implemented a geometry change via usrdat, but when I
reload the previous solution (which contains xyz), it overwrites my
changes and uses the geometry on which the solution was originally computed.
To work around this, is it OK to just comment out line 367 in ic.f?
c         call geom_reset(1)  !  recompute geometric factors
Would this cause the old data to be mapped onto the new grid?
Markus
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
