[Nek5000-users] fields on a regular grid
Thu Mar 10 08:55:02 CST 2011
Dear Paul,
Thanks for your reply. And apologies too for replying so late. I was
traveling which made replying to the mails quite difficult.
Coming back to the problem, I agree that doing the job in the post
processing mode would have been much easier. However, we can try your
second suggestion. It looks quite complicated right now. Let us get
back to you once we do that.
with thanks and regards,
Supriyo
On 06/03/2011, nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Supriyo,
> I'm quite certain we don't have what you desire, particularly
> since your input .rea file is not itself lexicographically ordered.
> One suggestion that I think would be of value is to generate your
> .rea file as a single tensor-product (i.e., lexicographically ordered)
> entity, by explicitly inputting the x- y- and z- ordinates.  The new
> box file would look something like:
> 10 10 10 nelx,nely,nelz
> 0 .05 .1 .2 .35 .5 .65 .8 .9 .95 1.
> Note, because of the way genbox was written, you can have only 80
> characters on an input line, so if you have more elements than
> can fit on a single line, you must wrap them.  As an example,
> the following yields the same result as above:
> 0 .05 .1 .2 .35
> .5 .65 .8 .9 .95 1.
> 0 .05 .1 .2 .35
> .5 .65 .8 .9 .95 1.
> 0 .05 .1 .2 .35
> .5 .65 .8 .9 .95 1.
> I use a script or short f77 program to generate my desired
> coordinate lists.   (The "negative" nelx option was just
> a shortcut to automatically provide commonly used distributions.)
> With the data organized in this way it will be easier to transfer
> into other formats.  For example, you'll have some hope of doing
> tensor-product operations.   If you already have a lot of data
> in your old layout you can use the grid-to-grid interpolation
> feature to transfer the data to the tensor-product-ordered mesh.
> See g2gi on the wiki page for how to do this.   You should check
> the veracity of the g2gi output -- I would recommend interpolating
> the coordinates (xm1,ym1,zm1) as a test.
> Coming back to your original question, even once the data is
> in a regular SEM array, we don't have any parallel mechanism
> to repartition the n x n x n grid data onto P processors because
> we never have a need for such.   We do have off-line serial routines
> that can transfer data from an nelx x nely x nelz array of Nth-order
> elements to an nxnxn array - this allows for analysis by FFTs etc.
> Also, if your elements on each processor compose a "perfect" block
> decomposition of the space, then you could locally reorganize the
> data into the sub-block of the global nxnxn array.  That is, if
> you had, say, 16 processors and an 8x8x8 array of elements, with
> contiguous 2x2x2 blocs on each of the processors, then the
> remapping would be local.
> As I type this, I realize now that we have a tool that could be
> used to re-order the data.   I'm going to express it under
> the assumption that your data is a proper tensor-product of
> nelx x nely x nelz elements --- if it is not, you simply need
> to figure out where in such an array element eg out of nelgv
> elements total is located.
> Assuming the (nelx,nely,nelz) layout such that nelgv=nelx*nely*nelz,
> then
>        include 'SIZE'
>        include 'TOTAL'
>        include 'ZPER'
>        integer e,eg,ex,ey,ez
>        do e=1,nelv
>           eg = lglel(e)
>           call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
>        enddo
> would tell you the (ex,ey,ez) index for element e in your (nelx,nely,nelz)
> array.   From this, you can discern your local 1D point sets
>      {i,j,k} in [1:n,1:n,1:n]
> required for each element.  Given this, you get a set of values
>      {xi,yj,zk} in [0,1]^3
> and you can use a tensor-product of 1D interpolators to map from
> element e to the desired  u_ijk values.  Use fd_weights_full in
> nek to generate the polynomial interpolants from the SEM mesh to
> your 1D coordinates.  It will output an interpolation matrix.
> Then you need to apply this interpolator in a tensor-product
> fashion to each element e, e=1,nelv, on each processor.
> ("grep weights *.f" in the trunk/nek directory to see example
> usage).
> You then need to organize your nxnxn data according to your desired
> processor layout.   If this requires data movement, I think you can
> use crystal_ituple_transfer and sort (grep crystal *.f).
> The key here is to exploit the underlying tensor-product layout
> of both the input and output data.  This allows you to use a
> tensor-product of 1D interpolators, rather than general-purpose
> off-grid interpolation, which is more expensive and generally
> less accurate.   A (very) good idea is to choose your "n" distribution
> so that none of the desired output values is on a spectral element
> boundary.  Otherwise, there is ambiguity about which element or
> processor is responsible for keeping this value.  Even if you decide
> to use a rule controlled by, say, less-than-or-equal, you can get
> into trouble because of floating-point round-off so that the data
> does not end up where you think it should.
> If this seems complicated, well, it is -- primarily because you
> desire to move between two data spaces.   Again, I reiterate that
> we have these tools in serial (which is where we would typically
> post-process under such circumstances).
> Paul
>> Dear Paul,
>> Thanks for your prompt reply. We greatly appreciate it.
>> Yes, our domain is box shape (3d). Our mesh is equal in all three
>> directions. Please
>> find attached the .box file for your reference.
>> We are running NEK in parallel. We want the array to be equipartitioned
>> among all
>> the processors. Array size = cube_root(number_elements)*order_polynomial.
>> We do not want the regular array to be output to a file.
>> with regards,
>> Supriyo
>> On Sat, 5 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> > Dear NEK developers,
>> > We are trying to get velocity and temperature fields on a regular grid
>> > as
>> > separate arrays (not being dumped in some file).
>> > map2reg in postprocess.f seems to be doing that. However we are confused
>> > with the dimensionality of the output array in that function.
>> > Please help us in this regard.
>> > With best wishes
>> > Supriyo Paul
> Nek5000-users mailing list
Dr. Supriyo Paul
Senior Project Scientist
Department of Physics
Indian Institute of Technology
Kanpur  208 016
INDIA
