[Nek5000-users] Method to detect NaNs
Tue Mar 8 16:02:57 CST 2011
Thanks for the tip Josh!
It's a clever one that I had not thought of.
I typically am running on a machine where I've set the compiler
to halt execution on occurance of 1st NaN, but that doesn't address
the issue you raise.   Your solution is great.
Paul
On Tue, 8 Mar 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I just wanted to pass on a method that may or may not be useful to you all.
> I'm sure manyf NEK simulations are run on machines where the hours
> aren't "free."  Thus, it's nice to try and minimize any wasted hours
> as much as possible.  So, if a simulation blows up, you want to end
> the simulation as quickly as possible so as to not waste any more
> precious computational time.
> While there are probably better solutions, I end up putting the
> following snippet into my userchk()
> if (u_max.ne.u_max) then
>           if (nid.eq.0) print *,'Sim is blowing up!!'
>           call exitt()
> endif
> where u_max is something I calculated before hand.  An interesting
> property of NaNs I found after doing some googling is that NaNs are
> not equal to anything..even themselves.  So, if you take some
> quantity, and compare it to itself, the only time it isn't equal to
> itself is if it is Not a Number.  You can use this property to tell
> your simulation to quit.  I've tested this out on a case that I knew
> would blow up on me and it worked perfectly.
> Hope you all find this helpful for "hazardous" jobs when you can't
> spare the time to monitor its progress at all times.
> Josh Camp
> "All that is necessary for the triumph of evil is that good men do
> nothing" -- Edmund Burke
> Nek5000-users mailing list
