[Nek5000-users] Adjoint perturbation
Tue Jun 21 13:47:59 CDT 2011
Hi Jean-Christophe,
It looks like the only place in the code where ifadj shows up is in
perturb.f:107
       if (ifnav.and.(.not.ifchar).and.(     ifadj))call advabp_adjoint
so you can set ifadj=.true. somewhere in userchk or usrdat -- just make
that you also add
       include 'ADJOINT'
there which is not part of 'TOTAL'
Best,
Aleks
On Tue, 21 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Nek's,
> I have seen the adjoint perturbation mode has been added to the current.
> Where/how do I have to specify ifadj = .true. if I want to use it? Is there
> some parameters in the .rea file like for direct perturbation mode?
> Sincerely,
> On 9 June 2011 11:50, Jean-Christophe Loiseau <loiseau.jc at gmail.com> wrote:
>> Hi Neks,
>> I was just wondering if the adjoint linear solver has already been released
>> in the current repo or not?
>> Regards,
>> On 6 May 2011 15:49, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Dear Jean-Christophe,
>>> My apologies for the delay in getting back to you - we've been
>>> saturated with proposal writing on our end.
>>> Your approach looks reasonable -- though I would avoid at all
>>> costs the f90 type declarations and stick with the std f77-based
>>> approach to be consistent with the code.
>>> I'll look into your proposed approach.  I should point out also
>>> that we've recently had an adjoint solver developed by some colleagues
>>> that is ready to go into the svn repo.  I've just
>>> been delayed in getting it in because of travel and proposals.
>>> My hope is that this will be in the repo in about 10-15 days.
>>> Regarding the proper choice of gradm1 vs wgradm1, the question
>>> ultimately comes down to the degree of differentiability of the
>>> input --- functions in nek are only C0 and hence one-time differentiable.
>>> This applies also to the test functions.  Thus, the std. practice
>>> is to move a derivative from the solution to the test functions (i.e.,
>>> to use the weak derivative) whenever the solution is to be differentiated
>>> twice.
>>> Regards,
>>> Paul
>>> On Thu, 5 May 2011, nek5000-users at lists.mcs.anl.gov wrote:
>>>  Hi Nek's,
>>>> I am interested into the linear adjoint perturbation. The equations read:
>>>> -du/dt = (U.Grad) u - transpose(Grad(U)) u + 1/Re Laplacian(u) - grad(p)
>>>> div(u) = 0
>>>> Assuming t' = T-t, one can rewrite: du/dt' = (U.Grad) u -
>>>> transpose(Grad(U))
>>>> Only small modifications to the perturbation mode are necessary, mainly
>>>> to
>>>> evaluate the tranpose gradient terms. Here is what I've done to evaluate
>>>> these:
>>>>     subroutine conv_adj(conv_x,conv_y,conv_z,u_x,u_y,u_z) ! used to be
>>>> conv1n
>>>>     include 'SIZE'
>>>>     include 'DXYZ'
>>>>     include 'INPUT'
>>>>     include 'GEOM'
>>>>     include 'SOLN'
>>>>     include 'TSTEP'
>>>>     parameter (lt=lx1*ly1*lz1*lelt)
>>>>     real u_x (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_y (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_z (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_xx (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_xy (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_xz (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real u_yx (size(vy,1),size(vy,2),size(vy,3),size(vy,4))
>>>>     real u_yy (size(vy,1),size(vy,2),size(vy,3),size(vy,4))
>>>>     real u_yz (size(vy,1),size(vy,2),size(vy,3),size(vy,4))
>>>>     real u_zx (size(vz,1),size(vz,2),size(vz,3),size(vz,4))
>>>>     real u_zy (size(vz,1),size(vz,2),size(vz,3),size(vz,4))
>>>>     real u_zz (size(vz,1),size(vz,2),size(vz,3),size(vz,4))
>>>>     real conv_x (size(vx,1),size(vx,2),size(vx,3),size(vx,4))
>>>>     real conv_y (size(vy,1),size(vy,2),size(vy,3),size(vy,4))
>>>>     real conv_z (size(vz,1),size(vz,2),size(vz,3),size(vz,4))
>>>>     *call gradm1(u_xx,u_xy,u_xz,u_x)*
>>>> *      call gradm1(u_yx,u_yy,u_yz,u_y)*
>>>> *      call gradm1(u_zx,u_zy,u_zz,u_z)*
>>>> *      conv_x = vx*u_xx + vy*u_yx + vz*u_zx*
>>>> *      conv_y = vx*u_xy + vy*u_yy + vz*u_zy*
>>>> *      conv_z = vx*u_xz + vy*u_yz + vz*u_zz*
>>>>     return
>>>>     end
>>>> However, I'm not sure I've done it properly or not (arrays declaration
>>>> for
>>>> instance). Especially, I had no idea wheter I have to use the gradm1
>>>> subroutine or its weak counterpart wgradm1. Finally in perturb.f, I've
>>>> slightly change the advap subroutine the following way:
>>>> subroutine advabp
>>>> C
>>>> C     Eulerian scheme, add convection term to forcing function
>>>> C     at current time step.
>>>> C
>>>>     include 'SIZE'
>>>>     include 'INPUT'
>>>>     include 'SOLN'
>>>>     include 'MASS'
>>>>     include 'TSTEP'
>>>> C
>>>>     COMMON /SCRNS/ TA1 (LX1*LY1*LZ1*LELV)
>>>>    $ ,             TA2 (LX1*LY1*LZ1*LELV)
>>>>    $ ,             TA3 (LX1*LY1*LZ1*LELV)
>>>>    $ ,             TB1 (LX1*LY1*LZ1*LELV)
>>>>    $ ,             TB2 (LX1*LY1*LZ1*LELV)
>>>>    $ ,             TB3 (LX1*LY1*LZ1*LELV)
>>>> C
>>>>     ntot1 = nx1*ny1*nz1*nelv
>>>>     ntot2 = nx2*ny2*nz2*nelv
>>>> c
>>>>     if (if3d) then
>>>>        call opcopy  (tb1,tb2,tb3,vx,vy,vz)                   ! Save
>>>> velocity
>>>>        call opcopy  (vx,vy,vz,vxp(1,jp),vyp(1,jp),vzp(1,jp)) ! U <-- du
>>>>      *  call conv_adj(ta1,ta2,ta3,tb1,tb2,tb3)*
>>>> *         call opcopy  (vx,vy,vz,tb1,tb2,tb3)  ! Restore velocity*
>>>> *c*
>>>> *         do i=1,ntot1*
>>>> *            tmp = bm1(i,1,1,1)*vtrans(i,1,1,1,ifield)*
>>>> *            bfxp(i,jp) = bfxp(i,jp)-tmp*ta1(i)*
>>>> *            bfyp(i,jp) = bfyp(i,jp)-tmp*ta2(i)*
>>>> *            bfzp(i,jp) = bfzp(i,jp)-tmp*ta3(i)*
>>>> *         enddo*
>>>> c
>>>>        call convop  (ta1,vxp(1,jp))       !  U.grad dU
>>>>        call convop  (ta2,vyp(1,jp))
>>>>        call convop  (ta3,vzp(1,jp))
>>>> c
>>>>        do i=1,ntot1
>>>>           *bfxp(i,jp) = bfxp(i,jp) + tmp*ta1(i)*
>>>> *            bfyp(i,jp) = bfyp(i,jp) + tmp*ta2(i)*
>>>> *            bfzp(i,jp) = bfzp(i,jp) + tmp*ta3(i)*
>>>>        enddo
>>>> c
>>>>     else  ! 2D
>>>> c
>>>> velocity
>>>>        call opcopy  (vx,vy,vz,vxp(1,jp),vyp(1,jp),vzp(1,jp)) ! U <-- dU
>>>>        call convop  (ta1,tb1)                                ! du.grad U
>>>>        call convop  (ta2,tb2)
>>>> c
>>>>        do i=1,ntot1
>>>>        enddo
>>>> c
>>>> c
>>>>        do i=1,ntot1
>>>>        enddo
>>>> c
>>>>     endif
>>>> c
>>>>     return
>>>>     end
>>>> Any help to spot potential erros or to speed up these operation would be
>>>> highly appreciated.
>>>> Best regards,
>>>> Jean-Christophe
>>>>  _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Jean-Christophe
> Jean-Christophe
