[Nek5000-users] Number of elements for 3D simulations
Thu Jun 16 07:43:23 CDT 2011
Hi Paul,
yes, only my spanwise direction ("t") is periodic.
David
On 06/16/2011 02:25 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi David,
> You're refering to periodic, correct?
> Is your spanwise direction the "z" direction in the element? (really,
> what we call "t"...)
> We might be able to correct the issue for this particular case,
> assuming you don't have periodicity in the other directions.
> Paul
> On Thu, 16 Jun 2011, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello,
>> I wanted to ask if it would be possible to allow to run nekton with less
>> than 3 elements in the z-direction. I run a lot of simulations for a
>> spanwise homogeneous swept wing geometry. The baseflow can be obtained
>> solving a 2D problem where the heat equation is solved as the spanwise
>> momentum equation. However, I also want to study the stability of this
>> flow and thus solve the linearised Navier-Stokes eq. for some modal
>> disturbances, i.e. u(x,y,z) = u'(x,y)*exp(i*beta*z). If I would be able
>> to resolve this mode with less than 3 elements in the spanwise direction
>> it would save me a lot of computational time.
>> Best regards,
>> David
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
