[Nek5000-users] Postx
Fri Jan 14 19:19:32 CST 2011
Hi Himanshu,
Sorry, I forgot the name of the file:
nek5_svn/trunk/tools/postnek/basics.inc
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, January 13, 2011 2:59:27 PM
Subject: Re: [Nek5000-users] Postx
Hi Aleks,
Thank you for the suggestion. In the postnek directory there are many .f files, do you know which one has the MAXFLD parameter?
Himanshu
On Thu, Jan 13, 2011 at 3:37 PM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hi Himanshu,
Try to increase MAXFLD parameter in nek5_svn/trunk/tools/postnek (i.e., maximum total number of fields in .fld file) and recompile clean.
Best,
Aleks
On Thu, 13 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
Hello neks,
I am trying to use postx to read some fld files that have passive scalar
information. There are 3 passive scalars. The passive scalar options appear
when I do "Set Quantity". But, when I try to set the plot format and read
the input file, the passive scalar option is not shown in the Nekton menu.
The velocity, co-ordinates, temperature options are present. Any idea why
the passive scalar option does not appear?
Thank you,
Himanshu
On Tue, Jan 11, 2011 at 11:07 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
Hello Neks,
I am trying to post process the fld files using postx to generate a uniform
xy grid of passive scalar data. During post processing the top half of the
circular cross-section is cut-off (its a cylindrical domain with aspect
ratio of 10 i.e radius to depth). The output file generated has only zeros
in it. I have checked the input file and it has information of the entire
domain. Any idea if i need to do something differently.
Himanshu
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
