[Nek5000-users] Compilation error
Wed Jan 12 15:25:08 CST 2011
when compiling a medium size case, i obtained this error message:
obj/prepost.o: In function `fill_tmp_':
prepost.f:(.text+0x2e89): relocation truncated to fit: R_X86_64_32S
against symbol `scrcg_' defined in COMMON section in obj/gmres.o
obj/prepost.o: In function `outhis_':
prepost.f:(.text+0x5571): relocation truncated to fit: R_X86_64_32S
obj/prepost.o: In function `prepost_map_':
prepost.f:(.text+0x6f34): relocation truncated to fit: R_X86_64_32S
obj/ic.o: In function `mfi_':
ic.f:(.text+0xa33): relocation truncated to fit: R_X86_64_32S against
obj/planx.o: In function `updrhsh2_':
planx.f:(.text+0x22): relocation truncated to fit: R_X86_64_32S against
symbol `vrthoi_' defined in COMMON section in obj/planx.o
obj/planx.o: In function `updtseth2_':
planx.f:(.text+0x3b0): relocation truncated to fit: R_X86_64_32S against
planx.f:(.text+0x3c1): relocation truncated to fit: R_X86_64_PC32
against symbol `vrthoi_' defined in COMMON section in obj/planx.o
planx.f:(.text+0x3e2): relocation truncated to fit: R_X86_64_32S against
planx.f:(.text+0x42d): relocation truncated to fit: R_X86_64_32S against
planx.f:(.text+0x4b4): relocation truncated to fit: R_X86_64_32S against
obj/planx.o: In function `projh2_':
planx.f:(.text+0x61d): additional relocation overflows omitted from the
output
collect2: ld returned 1 exit status
make: *** [nek5000] Error 1
Any help?.
Thanks in advance.
