[Nek5000-users] First Visit file
Thu Jan 6 12:14:56 CST 2011
Hello,
For some reason you have ASCII format which is usually triggered by param(66)<0 in .rea or an overwrite in .usr file with param(66)=0 instead of repo's param(66)=4 -- could you check you .usr file?
Visit reader may not work with it since it's optimized to work with large datasets for which ASCII format is prohibitive.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, January 6, 2011 12:04:11 PM
Subject: Re: [Nek5000-users] First Visit file
I used a test case (10 dump files from test1.fld01 to test1.fld10) which
head sections look like this (test1.fld01):
 100  12  12   1 2.0000000E-02   10 X Y U P
NELT,NX,NY,N
  0.000      0.000      0.000      0.000      0.000      0.000
  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00  1.154895E+01
  2.755036E-03  0.000000E+00  0.000000E+00  0.000000E+00  1.080465E+01
  9.036034E-03  0.000000E+00  0.000000E+00  0.000000E+00  9.776687E+00
the test1.nek3d file obtained after running the script contains:
NEK3D
filetemplate: test1.fld%02d
firsttimestep: 1
numtimesteps: 10
meshcoords: 1
However Visit is unable to read it:
The file format reader issued the following error message, which may (or
may not) be indicative of the problem:
VisIt believes this is a "Nek" file. Further, the reader for this format
believes this is a non-compliant file of this type. Its description of
non-compliance is: "A tag called filetemplate: must be specified"
Thanks.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
