[Nek5000-users] First Visit file
Thu Jan 6 09:47:07 CST 2011
I'm not certain that r1492... has the requisite geometry
in the .fld file.  (nek5000 and postx do not require it)
Also, it might be a good idea to start w/ .fld01, so I
would suggest actually running the case and generating
a sequence of a few .fld files (at least one).  Nek5000
will put the geometry in .fld01 by default.
Then, execute the following script:
#! /usr/bin/tcsh
  set base = `head -1 SESSION.NAME`
  echo '\n Generating '$base'.nek3d file ...'
  set nfld = `ls $base.fld* | wc -l`
#echo $base  ' '  $nfld
  echo 'NEK3D'                           >  $base.nek3d
  echo 'filetemplate: '$base'.fld%02d'   >> $base.nek3d
  echo 'firsttimestep: 1'                >> $base.nek3d
  echo 'numtimesteps: '$nfld             >> $base.nek3d
  echo 'meshcoords: 1'                   >> $base.nek3d
  echo '\n Assuming that coordinates are in '$base'.fld01 -- otherwise edit $base.nek3d file ...'
  echo '\n Total : '$nfld' file(s)  ... Done \n'
# Extra lines?
# version: 1.0
# endian: big
#ls `head -1 SESSION.NAME`0.f[0-9][0-9][0-9][0-9]* | wc -l
which will make a blah.nek3d file for session name "blah"
(assuming blah is in your SESSION.NAME file).
>From this you can run visit and load blah.nek3d
Paul
On Thu, 6 Jan 2011, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I am trying to open the binary example file in /nek5_svn/examples/vortex
> named r1492_n08.fld27 but i received the following error message:
> VisIt could not read from the file
> "/home/alex/Documents/nek5_svn/examples/vortex/r1492_n08.fld27".
> The generated error message was:
> There was an error
> opening /home/alex/Documents/nek5_svn/examples/vortex/r1492_n08.fld27.
> It may be an invalid file. VisIt tried using the following file format
> readers to open the file: Silo
> To check if visit was working fine I generated a bov ASCII file and open
> it with no problems.
> Thanks.
> Nek5000-users mailing list
