[Nek5000-users] turbulent channel flow
Wed Feb 2 08:35:58 CST 2011
I am trying to reproduce the results for the turbulent channel flow
using DNS.
However, instead of using the bulk velocity or the flow rate to drive
the flow, I would like to use a mean pressure gradient.
Using the non-dimensional equations resulting from selecting the
friction velocity (u_tau) as the velocity scale, only the Reynolds
number based on u_tau needs to be specified because the mean pressure
gradient is equal to -1.
Consequently the pressure gradient in the streamwise direction is grad
p=-1+grad p* where * means fluctuation.
I assumed that this could be done by simply setting:
ffx=1.0
ffy=0.0
ffz=0.0
in subroutine userf.
All my trials initializing the flow with some kind of synthetic
turbulent flow ended up damping the fluctuation and converging towards
the laminar solution.
Any help?.
Alexandre Fabregat, PhD.
Mail: afabrega at uottawa.ca
Phone: 630 562-5800 (ext. 6293)
Office: B207
Mechanical Engineering Department
University of Ottawa
161 Louis Pasteur, K1N6N5, Ottawa ON
