[Nek5000-users] Failure with TORDER = 3 (P027)
Wed Dec 7 08:11:36 CST 2011
BDF2 is more robust than BDF3. I used it successfully for my diffuser.
Johan
nek5000-users at lists.mcs.anl.gov wrote:
> Dear All,
> I have been conducting a direct numerical simulation of turbulent pipe
> flow
> using nek5000 at a moderately high Reynolds number (at present
> Re_tau=550).
> For this, I have to use a very fine grid in order to capture the flow
> physics accurately (for a length of 25R, I am using a total of 450
> million
> grid points when assuming a polynomial order 7). However, I have been
> having
> problems with the stability of the code when using TORDER = 3, i.e.
> parameter 027. The way I conducted my simulation was as follows:
> - I started with polynomial order 3, TORDER set to 3, and run for 4 flow
> through times, starting from random noise. At this point I had the
> projection parameters, i.e. P094 and P095 set to non-zero values.
> - Afterwards, I increased the polynomial order to 5, with TORDER kept
> at 3,
> and ran for another 2 flow through times. Here, I set the projection
> parameters P094 and P095 to zero.
> - Now, starting from the last field of the previous run, I changed to my
> target polynomial order 7, and keeping TORDER = 3. However, the codes
> explodes shortly after restarting. The error is: "failed in HMHOLTZ."
> I also tried a considerably lower time-step, but the problem persisted.
> Meanwhile, when I change TORDER to 2, the code runs fine and does not
> explode. The "physical" results are absolutely fine, and the statistics I
> get are in perfect agreement to our expectations.
> I did not get the same problem while running a turbulent pipe flow at a
> lower Reynolds number (Re_tau=180) and with less grid points.
> Probably also of importance, I did test with various ways of restarting,
> i.e. storing in fld or f files, using 4 or 8 byte accuracy, and storing
> multiple consecutive fields for the multi-step time scheme. None of these
> changes made significant impact. Also, I am using overintegration and
> filtering (0.01 in parameter P103); increasing the filtering (by a
> factor of
> 5) did also not help.
> I am wondering if any faced a similar issue before, and if would have an
> insight on how to tackle it. Could my problem maybe be related to the
> restart-issue that Adam brought up recently?
> Best regards
> George
> This message was sent using IMP, the Internet Messaging Program.
> Nek5000-users mailing list
Johan Malm
Department of Mechanics, KTH
SE-100 44, Stockholm, Sweden
Phone: +46 8 7906876
E-mail: johan at mech.kth.se
