[Nek5000-users] problem with DNS of heat transfer in a channel
Tue Oct 12 11:45:41 CDT 2010
Hello, Paul,
Thank you for your answer for the same problem last month.
But I still could not figure out this issue. (Domain:6.4/2.0/3.2,
Resolution: 12*8*12 elements with 8th order, turbulent Re_tau=178.12,
Pr=0.71) ,
piece of my *.rea file
   1.00000              DENSITY
   -178.12               Re_b
   0.000000E+00    BETAG
   0.00000              GTHETA
   0.000000E+00     PGRADX
   0.000000E+00     FLOWRATE
   1.0                       RHOCP
  -126.47                 CONDUCT
my *usr file
 subroutine userq  (ix,iy,iz,ieg)
     include 'SIZE'
     include 'TOTAL'
     include 'NEKUSE'
     ie   = gllel(ieg)
     qvol = vx(ix,iy,iz,ie)/15.771
     source = 0.0
     return
     end
Here 15.71 is averaged mean velocity over channel section.
After a long time running (dimensionless time > 350 )
 I compared the result ,  the velocity profile looks good.
But the temperature is much higher than Kasagi's result.
I'm wondering whether the parameters above are correct ?
 I attached the plot of mean velocity and mean temperature.
Thank you again
Zhicheng Wang
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101012/b620e30c/attachment.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101012/b620e30c/attachment.pdf>
