[Nek5000-users] Compiling issue, waiting for unfinished jobs...??
Mon Oct 4 07:24:50 CDT 2010
Michael:
It looks like the compiler cannot write some temporary files to the disk.
I am pretty sure this problem is unrelated to Nek and you system has somehow a problem.
-Stefan
----- Original Message -----
To: Nekton User List <nek5000-users at lists.mcs.anl.gov>
Sent: Mon, 4 Oct 2010 02:16:08 -0600 (GMT-06:00)
Subject: Re: [Nek5000-users] Compiling issue, waiting for unfinished jobs...??
Hi Michael,
Can you compile any other code w/ the same procedure?
Paul
On Mon, 4 Oct 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I can't get a run to compile, both with an old repo and the latest repo . I get the following error message during the compling :  It says something about waiting for unfinished jobs, and the a code generation return code. I don't know what it is talking about, but I have tried everything I know of and it still won't compile. I did quit a previous run using echo -1 which failed to fully write the f file, and this issue occurred right after, I don't know if this is related or not. As anyone had this problem before or know how to solve it?  I was able to get this case to run but now it is telling me this and I am stumped. This is the portion of the compile log where the error occurs and it quits.
> - Michael
> 1586-444 (U) An error occurred while writing to file "/scratch/cmm7686/ tmp /ipaD2JMab".
> 1501-511  Compilation failed for file mvmesh .f.
> gmake : *** [obj/ mvmesh .o] Error 1
> gmake : *** Waiting for unfinished jobs....
> "/home/cmm7686/nek5_548/trunk/ nek /navier1.f", 1500-036 (I) The NOSTRICT option (default at OPT(3)) has the potential to alter the semantics of a program.  Please refer to documentation on the STRICT/ NOSTRICT option for more information.
> 1586-444 (U) An error occurred while writing to file "/scratch/cmm7686/ tmp / ipaNHnCUa ".
> 1501-511  Compilation failed for file ssolv .f.
> gmake : *** [obj/ ssolv .o] Error 1
> "/home/cmm7686/nek5_548/trunk/ nek /navier1.f", 1500-016 (W) WARNING: Compiler problem occurred while compiling uzawa : Cannot exceed the user or group quota..
> "/home/cmm7686/nek5_548/trunk/ nek /navier1.f", 1500-034 (S) Cannot create object file.
> 1586-346 (U) An error occurred during code generation.  The code generation return code was 1.
> 1501-511  Compilation failed for file navier1.f.
> gmake : *** [obj/navier1.o] Error 1
> -bash-3.00$
