[Nek5000-users] nelt>lelt
Mon Nov 22 17:12:29 CST 2010
Hello all,
Anyone have any idea what could be causing the following error (I am
running 64 processes using 18432 elements)?
                  18422   18423   18424   18425   18426   18427   18428
18429
                  18430   18431   18432
 done :: mapping elements to processors
ABORT: nelt>lelt!        0    14179      288
My SIZE file follows.
C     Dimension file to be included
C
C     HCUBE array dimensions
C
      parameter (ldim=3)
      parameter (lx1=6,ly1=lx1,lz1=lx1,lelt=288,lelv=lelt)
      parameter (lxd=9,lyd=lxd,lzd=lxd)
      parameter (lelx=1,lely=1,lelz=1)
c
      parameter (lzl=3 + 2*(ldim-3))
c
      parameter (lx2=lx1-2)
      parameter (ly2=ly1-2)
      parameter (lz2=lz1-2)
      parameter (lx3=lx1)
      parameter (ly3=ly1)
      parameter (lz3=lz1)
c
c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
c
      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
      parameter (lpx2=1,lpy2=1,lpz2=1)
c
c
c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
c
      parameter (lbelv=1,lbelt=1)                ! MHD
      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
      parameter (lbx2=1,lby2=1,lbz2=1)
c
C LX1M=LX1 when there are moving meshes; =1 otherwise
      parameter (lx1m=lx1,ly1m=ly1,lz1m=lz1)
      parameter (ldimt= 11)                       ! 3 passive scalars +
T
      parameter (ldimt1=ldimt+1)
      parameter (ldimt3=ldimt+3)
      parameter (lp = 64)
      parameter (lelg = 18432)
c
c     Note:  In the new code, LELGEC should be about sqrt(LELG)
c
      PARAMETER (LELGEC = 1)
      PARAMETER (LXYZ2  = 1)
      PARAMETER (LXZ21  = 1)
c
      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
      PARAMETER (LXZ=LX1*LZ1)
      PARAMETER (LORDER=3)
      PARAMETER (MAXOBJ=4,MAXMBR=LELT*6,lhis=1)
C
C     Common Block Dimensions
C
      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
C
C     The parameter LVEC controls whether an additional 42 field arrays
C     are required for Steady State Solutions.  If you are not using
C     Steady State, it is recommended that LVEC=1.
C
      PARAMETER (LVEC=1)
C
C     Uzawa projection array dimensions
C
      parameter (mxprev = 20)
      parameter (lgmres = 30)
C
C     Split projection array dimensions
C
      parameter(lmvec = 1)
      parameter(lsvec = 1)
      parameter(lstore=lmvec*lsvec)
c
c     NONCONFORMING STUFF
c
      parameter (maxmor = lelt)
C
C     Array dimensions
C
      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
     $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
     $,NXD,NYD,NZD
c automatically added by makenek
      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
      parameter(lpart = 10  ) ! max number of particles
      integer ax1,ay1,az1,ax2,ay2,az2
      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) !
running averages
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Vienna University of Technology)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101123/6abcf371/attachment.html>
