[Nek5000-users] A small bug
Mon Nov 8 13:49:41 CST 2010
Yes - good eye!
I've changed this and it will be folded into the next svn update.
Thanks!
Paul
On Mon, 8 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> in the subroutine prepost.f, line 1156 (the sixth in the following piece
> of code) the format for the last item in the list (i.e. " 4 NELT,NX,NY,N")
> should be A15 and not A12 because of the additional spaces in the string
> corresponding to " 4 ". Is this correct?.
>            WRITE(24,'(4I4,1pe14.7,I5,1X,30A1,1X,A12)')
>     $           NELGT,NX1,NY1,NZ1,TIME,ikstep,(EXCODE1(I),I=1,30),
>     $           'NELT,NX,NY,N'
>         else
>            if (nelgt.lt.10000) then
>               WRITE(fhdfle,'(4I4,1pe14.7,I5,1X,30A1,1X,A12)')
>     $              ' 4 NELT,NX,NY,N'
> Post-doctoral fellow
> University of Ottawa
> Department of Mechanical Engineering
> Nek5000-users mailing list
