[Nek5000-users] Laplacian as a forcing function and stability issues
Thu Nov 4 16:30:14 CDT 2010
Hi Shriram,
Do you want to send .rea/.usr/SIZE in a tarfile?
I can take a look... I've been having good luck w/ dyn. smag.
of late.
Paul
On Thu, 4 Nov 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I am trying to implement a LES model which requires a term like c . Sij* to
> be added to the existing unfiltered viscous term. I am computing Sij* by
> filtering the velocity and calling comp_gije() twice. This is then included
> in the forcing function. This seems to work for few steps but the solution
> starts to blow up afterwards. I am wondering if this would be due to
> stability issues since the laplacian here is not calculated by any of the
> splitting methods. I would like to know if it would be possible to add this
> term to the Navier Stokes formulation that is solved each step. Any other
> ideas/ thoughts would be helpful. Thanks.
> Regards
> Shriram
