[Nek5000-users] [*] Re: Increasing data_files%d.f%04d to data_files%d.f%05d
Fri May 21 04:26:52 CDT 2010
Well, basically I am storing all the data and then post processing with
load_fld and your hpts subroutine. Maybe I should output less of the
binary and output probe data as the code is running. Anyway, I can
always put the last file and restart but thought that it'd be more
convenient to just increase the maximum limit since the code keeps
running even after f9999.
Thanks anyway,
Cheers,
Mani chandra
On 05/21/2010 01:14 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Wow you produced more than 9999 fld-files with a single NEK run?
> If you really want to have more digits you have to modify the source since we thought 4 digits would be enough.
> Stefan
> On May 21, 2010, at 9:42 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>>     How can one increase the maximum number of data_files that can be printed? After .f9999, nek stops outputting binary files, which is probably due to the %04 restriction. I'd like to know how to increase this limit.
>> Thanks,
>> Mani chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
