[Nek5000-users] Data output
Thu May 20 04:10:21 CDT 2010
In this case we use a uniform point distribution within the reference element instead of the GLL points.
Note, if the elements are deformed the output will not be uniform strictly speaking.
This feature is only support if you use the new binary output format (*.f????).
There is another tricky issue:
Make sure that you include the right CB (RESTART) in the subroutine you set ifreguo = .true. and remember to turn it off if you don't need it anymore.
I just realized that this is error prone and I will move ifreguo into another CB for greater accessibility (e.g. TOTAL).
Sorry for all the trouble
Stefan
On May 20, 2010, at 10:43 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Do you dump *.f???? or *.fld?? files?
> Stefan
> On May 20, 2010, at 10:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Nek's,
>> I have a little question concerning data output. I have read that it was possible to drop data on different mesh, regular / GLL / GL. The one I am interested in is the regular mesh, and there comes my problem.
>> I added ifreguo = .true. to the usercheck subroutine in the axi example, but I actually get no difference when it comes to the .fld file. I assume that I miss a step, but where ?
>> Regards,
>> Jean-Christophe
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
