[Nek5000-users] Seg fault (may be from Hpts routine)
Wed May 19 17:25:54 CDT 2010
Hello Stefan,
I tried the updated hpts routine ( version 518 ) and was having seg fault
issues. I tried under two different compilers ( intel and pgi ) and was
getting the seg fault error in both cases. I tried the same case without
calling the hpts routine and that works fine.
Error -1 :
<code>
[i124-101:13913] *** Process received signal ***
[i124-101:13913] Signal: Segmentation fault (11)
[i124-101:13913] Signal code: Address not mapped (1)
[i124-101:13913] Failing at address: 0x1e29b000
</code>
Is that an issue with compiler /mpi or something else ? Thanks for any help.
Regards
Shriram
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100519/dbf8f5cd/attachment.html>
