[Nek5000-users] [*] Re: RB convection with high Rayleigh numbers
Sat May 15 18:08:21 CDT 2010
Hi Mani,
What type of bcs are you using ?
I'm testing out a case, just to help scope out resolution requirements,
etc.
Paul
On Sun, 16 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
>    Thanks for the reply. I have a doubt whether one should increase the
> polynomial order or the number of elements with a fixed order for this case.
> As I understand from your illustration of the rotating cone case, increasing
> the polynomial order leads to a much better solution than with the same
> number of points generated using more elements with a lower order polynomial.
> Also how do I use the fast tensor-product solver? Is there some flag that I
> need to turn on?
> Regards,
> Mani chandra
> On 05/15/2010 09:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Mani,
>> I've not tried to go this high yet, but there are several std
>> techniques to pushing the envelope.
>> First, you should try to get an estimate of your expected resolution
>> requirements at the target Ra.   Then, guess that you might want to
>> run that simulation at say, lx1=10 or 12; and build the corresponding
>> mesh (number of elements in x and y); but start the compuation at
>> much lower Ra, with lx1=4, say.
>> Then work your way up in Ra, say by a factor of 10 in each successive
>> run, while also increasing lx1 as needed.
>> Note that for the flow in a box, you might find it faster to use
>> the fast tensor-product solver for the pressure, if using the Pn-Pn-2
>> method --- this is not always the case, but for some very difficult
>> problems (e.g., highly refined meshes), it does work better.
>> Paul
>> On Sat, 15 May 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi,
>>>    I'm trying to simulate RB convection in a 2D box of aspect ratio 2:1.
>>> I'd like to simulate cases with Rayleigh numbers of the order of 10^7 -
>>> 10^8. But I'm barely able to do 10^5 and that too with a time step of
>>> 10^-6. For the mesh I took 8 spectral elements in the x direction and 4
>>> spectral elements in the y direction with 48 points within each of them.
>>> Is there any way one can reach higher Ra numbers?
>>> Regards,
>>> Mani chandra
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
