[Nek5000-users] RE : problem with closed internal boundaries
Tue May 11 14:10:01 CDT 2010
Hi Michael,
It seems that perhaps your mesh and/or grid mapping is messed up.  The
numbers concerning your mesh in your "out" file are huge:
 verify mesh topology
  9.90000000000000105E+021 -9.90000000000000105E+021  Xrange
  9.90000000000000105E+021 -9.90000000000000105E+021  Yrange
  9.90000000000000105E+021 -9.90000000000000105E+021  Zrange
 done :: verify mesh topology
>From one of my simulations:
  -1.51515151515152        1.51515151515152       Xrange
  -1.51515151515152        1.51515151515152       Yrange
 -0.500000000000000       0.500000000000000       Zrange
Cheers,
Frank
On Tue, 2010-05-11 at 20:57 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> Hello Frank,
> thanks for the quick answer. The Nek team should be relieved that the community is growing and that some users start to be able to help the newbies.
> I tried what you recommended and now that you've said it, it looks obvious that all the z parameters should be 1 for a 2D case, but this isn't changing a thing. I still get those NaNs.
> Do you have any other idea?
> Best,
> Michael
> De : nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] de la part de nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Date d'envoi : mardi 11 mai 2010 20:31
> À : nek5000-users at lists.mcs.anl.gov
> Objet : Re: [Nek5000-users] problem with closed internal boundaries
> Hello Michael,
> I am by no means knowledgeable concerning NEK, but will put my two-cents
> in by saying that I believe that all dimensions in the z-direction must
> be 1.  However, you have "parameter (lz2=lz1-2)" and "parameter
> (lz3=lz2)".
> Cheers,
> Frank
> On Tue, 2010-05-11 at 18:20 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
> > Hello Neks,
> > I'm trying to model a flow past an obstacle in a channel. As a first step I would like to do a 2D simulation.
> > I'm encountering some problems during the geometry data generation in the nek5000 execution : it looks like the program can only generate NaN values although genmap seems to work well on the .rea file.
> > I can also reopen the rea file with prenek without any problems.
> > Do you have any idea what is going wrong here?
> > Is it problematic to have a closed internal boundary condition?
> > Thanks in advance for any help.
> > Best,
> > Michael B
> > _______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> Technische Universität Wien (Technical University of Vienna)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Mechanics and Heat Transfer)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
