[Nek5000-users] perturbing interior variables
Mon May 10 08:09:11 CDT 2010
Hello all,
I am trying to perturb the temperature in a small part of the flow.
However, I only wish to perturb in the interior and not on a boundary.
I have the following in "userchk".  If I instead looped from "k=1,nz1"
instead of "k=2,nz1-1", would this change the BC's?  The general
question would be, does changing uvw & T in "userchk" change BC's or
does "userbc" override what is done in "userchk"?
Cheers,
Frank
        do 100 iel=1,nelv
        do 100 k=2,nz1-1
        do 100 j=2,ny1-1
        do 100 i=2,nx1-1
        if(((xm1(i,j,k,iel)-1.1)**2
     &    + (ym1(i,j,k,iel)-1.1)**2
     &    + (zm1(i,j,k,iel)-.45)**2)**.5.le..25)then
           t(i,j,k,iel)=.99*t(i,j,k,iel)
        endif
          enddo !n
100     continue
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
