[Nek5000-users] History points
Thu May 6 08:49:41 CDT 2010
Hi Guys,
yes the history point module needs a major overhaul. I don't like the way it works!
In fact we could do a much better job using our interpolation tool.
I just coded something up (without testing the code snipplet) very quicky but I think I should work out of the box.
How does it work:
- create a 'hpts.in' file
line 1: number of points
line 2:  X,Y,Z coordinates of a point 1
line n+1: X,Y,Z coordinates of point n
- set lpart >= n in the SIZE file
- call hpts() in userchk()
The results will be written to 'hpts.out' .
Enjoy
-Stefan
      subroutine hpts
c
c     dump velocity, temperature and ps-scalars for a given list
c     of points (read from file hpts.in) into a file (hpts.out)
c
      INCLUDE 'SIZE'
      INCLUDE 'TOTAL'
      parameter(nmax=lpart,nfldmax=ldim+ldimt)
      parameter(mi=4,mr=1+2*ldim+nfldmax)
      real    rTL(mr,nmax)
      integer iTL(mi,nmax)
      common /itlcb/ iTL
      common /rtlcb/ rTL
      common /outtmp / wrk(lx1,ly1,lz1,lelt,nfldmax)
      character*80 fname
      integer icalld,npoints,icount
      save icalld,npoints,icount
      data icalld  /0/
      data npoints /0/
      data icount  /0/
      nxyz  = nx1*ny1*nz1
      ntot  = nxyz*nelt
      if(icalld.eq.0) then
        icalld = 1
        npoints = 0
        write(6,*) 'reading hpts.in'
        open(50,file='hpts.in',status='old')
        read(50,*) npoints
        write(6,*) 'found ', npoints, ' points'
        do i = 1,npoints
           read(50,*) (rTL(1+j,i),j=1,ndim)
        enddo
        close(50)
        bb_tol = 1e-8  ! bounding-box test tolerance
        call intpts_setup(bb_tol)
        open(50,file='hpts.out',status='new')
        write(50,'(A)') '# time  vx  vy  [vz]  T  PS1   PS2 ...'
      endif
      nflds  = nfield + ndim-1 ! number of fields you want to interpolate
      ! pack working array
      call copy(wrk(1,1,1,1,1),vx,ntot)
      call copy(wrk(1,1,1,1,2),vy,ntot)
      if(if3d) call copy(wrk(1,1,1,1,2),vz,ntot)
      do i = 1,nfield-1
         call copy(wrk(1,1,1,1,ndim+i),T(1,1,1,1,i),ntot)
      enddo
      ! interpolate
      call intpts(wrk,nflds,iTL,mi,rTL,mr,npoints,nmax)
      ! write interpolation results to file
      if(nid.eq.0) then
        do ip = 1,npoints
           write(50,'(1p20E15.7)') time,
     &      (rTL(1+2*ndim+ifld,ip), ifld=1,nflds)
        enddo
      endif
      return
      end
On May 6, 2010, at 3:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
> P.S.
> Yes, Frank, the exact coordinates of the history points are written only when the code rans.
> But if for history points you choose the collocation points on the boundary of a spectral element -- those that have I,J,K equal to either 1 or lx1 -- than you can find out their coordinates from .rea ASCII file after the line
> *** MESH DATA ***
> where coordinates of the element edges are written.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Wednesday, May 5, 2010 4:45:11 PM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] History points
> Hi Aleks,
> My question is what is the logfile?  Perhaps you mean the output that
> NEK writes to the screen?  If so, then one would know the location of
> the point at which data is being dumped only after entering the i,j,k
> and element # of the point in the *.rea file....
> Cheers,
> Frank
> On Wed, 2010-05-05 at 23:37 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Thanks Aleks.
>> Concerning grep, it is a linux command that searches for the string
>> History in the logfile.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> Technische Universität Wien (Technical University of Vienna)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Mechanics and Heat Transfer)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
