[Nek5000-users] History points
Thu May 6 07:58:58 CDT 2010
Hi Frank,
If you run Nek5000 with a script like
nek5_svn/trunk/tools/scripts/nekb
or
nek5_svn/trunk/tools/scripts/nekbmpi
the output will be redirected in a file blah.log* and linked to logfile.
It is convenient to navigate the logfile (and the code) with unix/linux command 'grep', e.g.
grep "C=" logfile
shows CFL versus time, etc.
Use
man grep
to see all the options for the command grep.
Best,
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Wednesday, May 5, 2010 4:45:11 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] History points
Hi Aleks,
My question is what is the logfile?  Perhaps you mean the output that
NEK writes to the screen?  If so, then one would know the location of
the point at which data is being dumped only after entering the i,j,k
and element # of the point in the *.rea file....
Cheers,
Frank
On Wed, 2010-05-05 at 23:37 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> Thanks Aleks.
> Concerning grep, it is a linux command that searches for the string
> History in the logfile.
> Nek5000-users mailing list
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
