[Nek5000-users] genbox error
Mon May 3 07:13:25 CDT 2010
Hello all,
I have come across what may be an error in genbox.  It concerns reading
in data.  If instead of 8 elements, 7 are used or if the trailing zeros
are removed, all is fine.  It almost seems as if genbox has a limitation
on the length of the lines defining the element edges.
Cheers,
Frank
Reading      32 =       8       4       4 elements for box   1.
Reading       2 =
 error:           8           9
 error:           0           5
The following is the input file:
openboat2D.rea
-2                      spatial dimension
 2                     number of fields
#    Open boat with the Marangoni effect at the top surface.
Box
 8 4
 -4.000000 -3.946236 -3.806717 -3.497438 -3.000000 -2.500000 -2.000000
-1.500000 -1.000000
 -5.000000 -3.347128  0.000000  3.754690  5.000000
W  ,W  ,W  ,shl,    V bc's  ! NB:  3 characters each !
t  ,t  ,   ,   ,    T bc's  !      You must have 2 spaces!!
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
