[Nek5000-users] Representing Curved Side in any plane
Mon Mar 29 11:37:43 CDT 2010
Hi Markus,
Thanks -- I'll check into it.
Paul
On Mon, 29 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> just double-checked, that's what I did. I only ran it for one time step without
> any meaningful physics, though.
> Attached are all case files. The nek version I am using is revision 456.
> Markus
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Hi Markus,
>> Did you visualize this with VisIt and with the geometry
>> put out into (at least) the first .fld or .f file ?
>> Paul
>>> Hi,
>>> I was looking into the midpoint feature and generated a cube (1 element, x,
>>> y, z from 0 to 1) in prenek, then converted all edges to the midpoint
>>> notation with prenek, and then manipulated one edge in the rea file. This
>> is
>>> the resulting curved side section:
>>>  ***** CURVED SIDE DATA *****
>>>        12 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
>>>  1  1  0.500000       0.00000       0.00000       0.00000 0.00000     m
>>>  2  1   1.10000      0.500000       0.00000       0.00000 0.00000     m
>>> 10  1   1.00000     -0.500000      0.500000       0.00000 0.00000     m
>>> 11  1   1.00000       1.00000      0.500000       0.00000 0.00000     m
>>> 12  1   0.00000       1.00000      0.500000       0.00000 0.00000     m
>>> where edge 10 is supposedly not a straight line any more.
>>> When I run this in nek, however, the cube still comes out with straight
>>> edges.
>>> Are there any other parameters I need to set?
>>> I checked out the most recent nek version and overcame compilation issues
>>> with gcc-gfortran 4.4.3-4.fc12 from the fedora 12 repository.
>>> Thanks,
>>> Markus
>>>> Michael,
>>>> I've only recently added general purpose midside-node support,
>>>> which puts a point in 3-space for any one of the 12 edges and
>>>> nek then fits a parabola to this.
>>>> I'll set up an example that demos this.  The feature has limited
>>>> support at the moment -- but does work in nek5000 and generates
>>>> correct geometry.
>>>> Depending on what you are after, there may be other ways to
>>>> generate the geometry.   One of my favorite techniques is to
>>>> project a given input geometry onto the desired surface.
>>>> Paul
>>>> On Sat, 27 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>>  Hello Users,
>>>>  My question is in regard to the curved side data section in the REA
>>>> file.  I know that the first 3 terms describe the side, element, and
>>>> radius, but there are several other numbers that are currently zero, and
>>>> then the letter C.
>>>>  Background for the question: I have a situation where I would like to
>>>> curve an element edge in any plane. I know this is possible from
>>>> previous posts regarding a sphere.rea.
>>>>  I know that with two points and a radius, that is enough to describe a
>>>> circle in a plane.  But lets say I have a side where 2 pts lie on the
>>>> XY plane, but the center of the circle is located on the YZ plane for
>>>> example... the question is how to represent this in the REA. In the REA
>>>> you just give the element side ( 2 pts ) and the radius, which does fix
>>>> the circle center but the plane that contains the center is not
>>>> fixed.  So what I am wondering is what the other numbers in this
>>>> section do...if you could say, give the center instead of the radius, or
>>>> give a third point with the other 2 pts in the element side to fully
>>>> define the circle and plane.
>>>>  Also, Is it possible to curve the remaining 4 sides of the element
>>>> (edges 9, 10, 11, 12 that would be in the "z" direction) in the same
>>>> manner as edges 1-8? Thanks for any input on this matter!
>>>>  Regards,
>>>>  Michael Meador
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
