[Nek5000-users] Postprocessing
Wed Mar 24 11:00:16 CDT 2010
Dear Nek devs,
     I'm a bit confused regarding postprocessing. Is one supposed to run
a simulation and then run nek5k again to load the fld files using
load_fld() for postprocessing? Or can one compute the desired quantities
after every time step using userchk() and then output them in a file?
For example, how can I compute the vorticity using the differential
operators defined in the code? After computing the vorticity, can it be
outputted using the same fld files?
Mani chandra
