[Nek5000-users] seg fault
Tue Mar 23 22:12:29 CDT 2010
Hi David,
Can you send me the full logfile for the single processor case?
If you're getting to the point where a field file is being
generated then the issue is not where I suspected it was.
Of course, if the logfile is buffered we're likely stuck unless
you can run it interactively ?
Paul
On Tue, 23 Mar 2010, David Goluskin wrote:
> Hey Aleks
> I don't know how to see what timestep I failed on, but one fld file is
> output successfully (the initial condition, I guess).  Do you have any idea
> what the newest version of nek is that might work?  If not, I can figure
> that out.  Perhaps it would be helpful to you if I figured that out?
> Best,
> David
> On Tue, Mar 23, 2010 at 1:30 PM, Aleksandr Obabko <obabko at mcs.anl.gov>wrote:
>> Hi David,
>> Does you case crashes on the second timestep?  Mine does on our local
>> sicortex with new version of the code.  Could you run with old version of
>> the code for now?
>> Thanks,
>> Aleks
