[Nek5000-users] "genmap" trouble with periodic boundary conditions
Fri Mar 12 12:41:14 CST 2010
Hello,
I am trying to run a backward facing step geometry simulation. Making the
mesh with "genbox" works fine but "genmap" gives the following error. It
seems there is some problem with the periodic boundary conditions.
Input (.rea) file name:
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
 reading .rea file data ...
 start locglob_lexico:           8        5184       41472  0.1000000
 locglob:           1           1       41472
 locglob:           2          41       41472
 locglob:           3         485       41472
 locglob:           1        6305       41472
 locglob:           2        6305       41472
 locglob:           3        6305       41472
 done locglob_lexico:      6305      6305     41472         8
 start periodic vtx:        5184        6305
 abort: PERIODIC MISMATCH 2:
        1  5 P    ie
        0  4   je
   0.000000       0.000000      bc
           8  quit
Here is my bfs.box file.
bfs1.rea
-3                         spatial dimension (if negative dump .re2 file)
1                         number of fields
box_1
-32 -3 -12                nelx,nely,nelz (negative --> auto spacing)
0.0  17.92 1.03           x_0  x_1 ratio
-1.0  -0.5   1.25
0.0  6.0   1
W  ,O  ,W  ,   ,P  ,P     bc's  ! west,east,south,north,bottom,top
box_2
-0.5 0.0  0.8
0.0  6.0   1
W  ,O  ,   ,   ,P  ,P      bc's  ! west,east,south,north,bottom,top
box_3
-32 -6 -12                nelx,nely,nelz (negative --> auto spacing)
0.0 10.76 2.25
0.0  6.0   1
box_4
-8 -6 -12                 nelx,nely,nelz (negative --> auto spacing)
-5.0 0.0 0.85            x_0  x_1 ratio
0.0 10.76 2.25
0.0  6.0   1
v  ,   ,W  ,   ,P  ,P     bc's  ! west,east,south,north,bottom,top
I cannot figure out what this error means. If I change the periodic
boundary condition to any other b.c., it works.
This error started occurring after I did a "svn update tools" this
morning. Now "genmap" does not even run on an old .rea file.
Can anybody suggest me solutions for this.
Thanks a lot,
Harish Kanchi.
