[Nek5000-users] Something wrong when visualizing fld files with Visit...
Thu Mar 4 12:20:49 CST 2010
Is there a specific reason to dump your data in ASCII?
It is highly recommend to use the BINARY format!
Check param(66) and param(67) in your .rea file.
ASCII: values < 0 e.g param(66) = -1
BINARY: values >0 e.g. param(66) = 1
Also make sure the your .usr does not overwrite this setting.
Hth,
Stefan
On Mar 4, 2010, at 6:28 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
>    When I try to visualize the fld files using Visit, it runs fine for some time and then suddenly the subsequent images become all gibberish. When I modify the metadata file to start with the fld file which looks corrupted, it's image looks fine in Visit (although the time data is missing..) and all the following images look corrupted. What could be the problem?
>    I'm attaching a few fld files and their images along with the metadata file.
> Thanking you,
> Mani chandra
> <lid.fld99><lid.fld100><lid.fld101><fld99.tif><fld100.tif><vis.nek2d><SIZEu.txt><lid.map><lid.rea><lid.usr><Mail Attachment.txt>
