[Nek5000-users] Code output
Wed Mar 3 06:02:20 CST 2010
Helmholtz solver output (velocity solve):
>    499268    Hmholtz VELX:      9   2.9714E-11   1.3717E+07   3.0000E-10
col3: number of iterations (9)
col4: final residual (2.9714E-11)
col5: initial residual (1.3717E+07)
col6: solver tolerance (3.0000E-10)
Pressure solver output:
>   499268 U-Press std. :     91   2.9185E-08   3.0000E-08   2.6864E-03   8.4799E-02
col3: number of iterations (91)
col4: final residual (2.9185E-08)
col5: solver tolerance (3.0000E-08)
col6: initial residual (2.6864E-03 )
col6: elapsed solver time
hth,
Stefan
On Mar 3, 2010, at 12:46 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
>    I'm trying to solve for a lid driven cavity flow (in 2D for now) using NEK5000. The viscosity has been set to one and the lid is moving with a velocity of 10000. I don't understand the meaning of the numbers given in the code output. For ex:
> Step 499268, t= 6.8040858E-02, DT= 1.2825985E-07, C=  0.409 5.9000E+04 9.7954E-02
>             Solving for fluid
>     499268    Hmholtz VELY:      9   1.3165E-11   1.1815E+07   3.0000E-10
>      499268  DNORM, DIVEX  2.918545176353094E-008  2.918487500510926E-008
>     499268   6.8041E-02  9.2034E-02 Fluid done
> Step 499269, t= 6.8040986E-02, DT= 1.2825985E-07, C=  0.409 5.9000E+04 9.9300E-02
>             Solving for fluid
>     499269    Hmholtz VELX:      9   2.9708E-11   1.3713E+07   3.0000E-10
>     499269    Hmholtz VELY:      9   1.3158E-11   1.1809E+07   3.0000E-10
>    499269 U-Press std. :     91   2.9192E-08   3.0000E-08   2.6781E-03   8.6898E-02
>      499269  DNORM, DIVEX  2.919249585636570E-008  2.919235717748844E-008
>     499269   6.8041E-02  9.4083E-02 Fluid done
> Step 499270, t= 6.8041114E-02, DT= 1.2825985E-07, C=  0.409 5.9000E+04 1.0086E-01
>             Solving for fluid
>     499270    Hmholtz VELX:      9   2.9703E-11   1.3708E+07   3.0000E-10
>     499270    Hmholtz VELY:      9   1.3151E-11   1.1802E+07   3.0000E-10
>    499270 U-Press std. :     91   2.9200E-08   3.0000E-08   2.6698E-03   8.3875E-02
>      499270  DNORM, DIVEX  2.919940124964188E-008  2.920027044061877E-008
>     499270   6.8041E-02  9.1076E-02 Fluid done
> It would be great if someone could explain what the numbers mean. I'm worried about the numbers in the second column being of the order of 1E+07. Is that a problem? Also while specifying the boundary conditions, how can one specify user set boundary conditions for more than one boundary using userbc? Is there a parameter which one could check to see if the grid resolution if enough for the case there is being run or should we resort to checking for grid independence?
> The rea, map and usr files are attached.
> Thanking you,
> Mani chandra
> P.S I'd really like to thank the developers for releasing this software for free and for documenting it so as to spread it's usage.
> <lid.map><lid.rea><lid.usr>_______________________________________________
> Nek5000-users mailing list
