[Nek5000-users] E INVALID BC FOUND in genfast
Wed Jun 30 18:54:46 CDT 2010
Hi Paul,
I am also getting something similar, however it is referring to many elements with
 a "BC fail" and then gives the E INVALID BC FOUND. I have attached the case
and output log for referrence.
I checked the elements that it is referring to and the BC's are good, so I'm not sure
why it tells me this. I looked in fast3d.f and also couldn't figure out what "ierr and ierrmx"
refer to. Could explain what this error means or what it is checking for? Thanks
for any help!
- Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, June 25, 2010 1:39:43 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] E INVALID BC FOUND in genfast
Shriram,
It's indicating that one of the bcs for element 3912 is not valid.
What are those?
Paul
On Fri, 25 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi all,
> I am getting the following error when I try to run nek :
>   *0        3912  BC FAIL*
> *EXIT: E INVALID BC FOUND in genfast       3912*
> I grep-ed to the source code to get an idea of what the error actually
> means, but I couldn't comprehend whats going on in the code (fast3d.f) .
> Could anybody tell me what this error actually means ? I checked the
> Boundary condition of the particular element (3912) and everything seems to
> be OK.
> Thanks for any help.
> Regards
> Shriram Jagannathan
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100630/8a0222cd/attachment.html>
