[Nek5000-users] Periodic B.C and Genmap Issue
Thu Jun 24 12:24:25 CDT 2010
Hi Paul,
I am having a similar problem.
I am trying to generate a mesh for a 3D periodic channel flow with periodic
boundary conditions in x and z directions and walls on the y direction.
I use genbox and then genmap. But i got the same error of Shriram.
Note that i am having problems when i am using double periodic BCs :
P  ,P  ,W  ,W  ,P  ,P
but single BCs works fine :
P  ,P  ,W  ,W  ,W  ,W
W  ,W  ,W  ,W  ,P  ,P
W  ,W  ,P  ,P  ,W  ,W
Do you have a work around or a suggestion?
Thank you
francesco
My error is
 reading .rea file data ...
 reading .re2 file data ...
 start locglob_lexico:           8         512        4096
   0.2000000000000000
 locglob:           1           1        4096
 locglob:           2           9        4096
 locglob:           3          81        4096
 locglob:           1         729        4096
 locglob:           2         729        4096
 locglob:           3         729        4096
 locglob:           1         729        4096
 locglob:           2         729        4096
 locglob:           3         729        4096
 done locglob_lexico:       729       729      4096         8
 start periodic vtx:         512         729
         1 1  5  3  0.00000000E+00        1 shift
 abort: PERIODIC MISMATCH 2:
        1  5 P    ie
      449  6 P		  je
    449.0000000000000       0.0000000000000000E+000 bc
My .box file is :
turbChannel.rea
3                       spatial dimension
1                       number of fields
#       comments:       This is the box immediately behind the
#                       refined cylinder in Ugo’s cyl+b.l. run.
Box 1                           Pipe
-8 -8 -8                        Nelx Nely Nelz
0.0   6.28   1.0                x0 x1   ratio
-1.0   1.0    1.0               y0 y1   ratio
0.0   3.14   1.0                z0 z1   ratio
P  ,P  ,W  ,W  ,P  ,P           BC’s: (cbx0, cbx1, cby0, cby1, cbz0, cbz1)
-----Original Message-----
From: nek5000-users-bounces at lists.mcs.anl.gov on behalf of nek5000-users at lists.mcs.anl.gov
Sent: Thu 6/24/2010 6:22 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Periodic B.C and Genmap Issue
Hi Paul,
This post is in reference to the previous post by Michael (dated Jun 22).
When I try to get a map file for a rea file that has periodic vertices, I
get the following error. The rea file was generated the same way as before
(Gambit -> Nek through Matlab). I checked on Matlab by plotting the periodic
vertices and confirmed for a few faces that they are indeed periodic. Also,
as you had earlier suggested (with the new genmap), I tried changing the
tolerances fro 0.09 to 0.2 and I get the same periodic mismatch error. Could
you provide any leads on where things are going wrong  ? Please find below
the error message. Thanks.
<error>
Input (.rea) file name:
domain
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.09
 start locglob_lexico:           8        3912       31296
8.99999999999999967E-002
 locglob:           1           1       31296
 locglob:           2          36       31296
 locglob:           3        1224       31296
 locglob:           1        4851       31296
 locglob:           2        4851       31296
 locglob:           3        4851       31296
 done locglob_lexico:      4851      4851     31296        10
 start periodic vtx:        3912        4851
     1093  1 P    ie
        0  1   je
  4.14470000000000029E-003   0.0000000000000000       bc
           8  quit
</error>
Regards
Shriram
